Leaks..Leaks...and More leaks!!
Old Mar 11, 2008 | 09:08 AM
SpeedJunkyz's Avatar
damn I just did the oil change...literally like last week lol
Syn oil isnt cheap lol
Old Mar 11, 2008 | 09:14 AM
mdsevo06's Avatar
That's what I did, except less the one mile when I noticed the leak. I knew right away that I forgot to tape the second fitting.
Good luck.
Old Mar 11, 2008 | 09:17 AM
I was thinking I could just remove it, plug the hole then clean tape and reinstall
colonelfox's Avatar
I have the same leak as the original poster, though it's coming from the oil plug that used to feed my old turbo. I have yet to get it to seal completely. This is my 5th 4G63 powered Mitsu, and they all had an oil leak at some point. I also have a very small trans leak between the T-case and trans that's been there since I rebuilt the engine.
Old Mar 11, 2008 | 09:23 AM
phat_bastage's Avatar
The vacuum regulator nipple cracked upon putting the tranny back in. Took me forever to find it, then taking it out blind was a joke.
The TB seals were easy to fix but yea it was a bad leak as well.
Old Mar 11, 2008 | 09:32 AM
belizelittle39439's Avatar
hmmmm....how many miles are you guys seeing all these fluid leaks at? I've got 17k on my 06 IX MR, and have no such leaks. Not fluid, or boost. ::knocks on wood::
I'd just like to know when I should expect leaks to occur and where the most common spots are.
Old Mar 11, 2008 | 09:35 AM
My TB seals went at 25k - almost on the nose. My FI seals I noticed after I was tuned to 24.x lbs of boost (not the o-rings but the main fi seals). And I still have no fluid leaks.
Old Mar 11, 2008 | 09:41 AM
My oil has been leaking since 21k, I did my TB seals at 23-24. And I have 34 now.....I even think my tranny is leaking aswell, im still searching for it
Old Mar 11, 2008 | 09:50 AM
mdsevo06's Avatar
I have 34K on my IX, and after doing a Boost Leak Test last week, there was no leak at the TB. The shaft seals are not only related the miles, but also by time.
Old Mar 11, 2008 | 09:55 AM
wooooow you do alot fo driving in your evo
Old Mar 11, 2008 | 10:08 AM
travman's Avatar
I have 33k - almost 34k on my IX and my TB shaft seals aren't leaking yet either. Will be doing another boost leak test in the spring when the weather breaks, now that I said this they will be leaking...haha.
I installed them on a local Evo VIII here in Pittsburgh - was a piece of cake, I may do mine someday when I'm bored just for something to do.
Old Mar 11, 2008 | 10:12 AM
DanJ's Avatar
I think i have a leak in my gastank because i have to fill up every other day and it's getting expensive.
Old Mar 11, 2008 | 10:15 AM
mdsevo06's Avatar
See, I'm not the only one with those type of miles, on a IX.
And I hear you on the Bored and looking for new projects. Nothing like a warm garage, cold beer and some tunes, to make you come up with new projects.
Old Mar 11, 2008 | 10:29 AM
who says it needs to be warm I was out there last night with my clutch lol...nothing like cold garage to keep your cold beer.....cold.
What do you need for a boost test? I cant remember what was involved.
Sj
Old Mar 11, 2008 | 02:09 PM
mdsevo06's Avatar
I would recommened PPI for a Boost Leak Tester. Very well made and has a guage installed, so it all in front of you, when doing the test. There's a couple "How to" step by step, on how to test. If you don't have a compressor, you can pick up a 125psi tank at Walmart. I think I paid $23 at Walmart for one.
