Leaks..Leaks...and More leaks!!
Old Mar 10, 2008 | 09:00 PM
SpeedJunkyz's Avatar
Ok lets hear it!! Lets hear your most pestering leaks...
Maybe we all can come together and fix these leaks once and for all..Please use pictures to best explain your point...thanks.
Here is my little devil.....
You see that hose looking loop? Really I think its the oil pressure line thingy ma bobber! Anyone have the proper term for it? You can see it dripping in the first Pic
Well it appears to be leaking right above that thing and trickling down......
EDIT 3-12-08
Anyone with Leaks under the car, I.E liquid Leaks? T-case, erl-pan, tranny...etc...etc...?
SJ
Old Mar 10, 2008 | 09:18 PM
mcwop23's Avatar
me and my friends have that throttle body leak pretty bad. We'll probably find a bunch of smaller leaks once we get the works seal installed.
Old Mar 10, 2008 | 09:28 PM
The one where you have to replace those little o-rings on the plate?
I had to do mine, it was pretty easy
Old Mar 10, 2008 | 09:32 PM
wizzo 8's Avatar
I need those throttle body shaft seals also. Is this thread for oil leaks or all leaks?
Old Mar 10, 2008 | 09:35 PM
All leaks, but if its visable, take a picture of it I want to see it lol
Old Mar 11, 2008 | 08:10 AM
EVO196's Avatar
wow, i actually feel a lil better, I thought i was the only one w/ leaks....my mbc & tb leaks, I bought a TB & MBC hopefully no more leaks....
but i'll going to replace the seal rings in my tb for future reoccurrence
Old Mar 11, 2008 | 08:21 AM
Have alot of people had to replace the seals in the TB?
Old Mar 11, 2008 | 08:25 AM
N8THEGR8's Avatar
i replacement rings for my tb but have yet to put them on (no time). Im not positive they are leaking but the odds are against me so Im going to replace them anyways.
Old Mar 11, 2008 | 08:30 AM
mdsevo06's Avatar
Do a Boost Leak test, to find out. 10 to 12 psi should tell the truth.
Old Mar 11, 2008 | 08:45 AM
anyone have any ideas on how to fix my leak?(First post)
Old Mar 11, 2008 | 08:47 AM
travman's Avatar
The oil pressure sender?
Take it out and wrap with sealant tape and reinstall.........see if the leak goes away. Probably wasn't installed correctly......is this for an aftermarket oil pressure gauge?
If that doesn't fix it - buy a new sender and install it.
Old Mar 11, 2008 | 08:49 AM
mdsevo06's Avatar
If it's the one with two fittings, you have to seal both with tape. Ask me how I know.
Old Mar 11, 2008 | 08:50 AM
travman's Avatar
Um you know mbc's leak? they have a little bleeder hole in them.......disconnect the line from the pressure source to the mbc and cap it off when doing your boost leak test, never test with the mbc hooked up.
Old Mar 11, 2008 | 08:56 AM
I dont know if its for two, its in the pic uptop......If I remove it will it leak everwhere?
Trav I replied to your bov sale
Old Mar 11, 2008 | 09:02 AM
mdsevo06's Avatar
You'll need to do an oil change. Drain, then remove the fittings. Clean the fittings of oil and rap it with sealent tape. Reinstall and fill with new oil.
