Any ideas?
Old Mar 11, 2008 | 08:30 PM
personal_golf's Avatar
Veteran: Air Force
Any ideas?
Just recently, when I step on the gas up an onramp and get into boost, the RPM will jump up like normal accelerating...then drop about 500 RPMS then blast off like normal again. What's the deal? So quick recap...
Hit the accelerator
Starts to climb through boost to about 4300RPM
Will drop to about 3800RPM's
Then start haulin *** again all the way to 6K+ if I deem necessary
Mods include:
Cams
Alcohol
93Oct
Intake
3" TB
Boost at 26
9 BOV
Perfectly safe tune by Ivey
Any ideas?
Thanks ahead of time!
Old Mar 11, 2008 | 08:36 PM
eponti's Avatar
Iam thinking boost leak
Old Mar 11, 2008 | 08:37 PM
importjake00's Avatar
me too
Old Mar 11, 2008 | 09:03 PM
ch53avitech's Avatar
Thats an easy one...boost leak...as stated above.
Old Mar 11, 2008 | 09:30 PM
Veteran: Air Force
Guess I figured it was "too easy"...that's why I didn't check for it. I usually overlook the easiest and overthink problems. Thanks ya'll, I'll check when it's lighter/warmer out tomorrow.
Old Apr 11, 2008 | 04:05 PM
Veteran: Air Force
ACT HD Street Disk w/Gruppe S lightened/forged flywheel goin in. Thanks ya'll!
Old Apr 11, 2008 | 04:15 PM
gsrboi80's Avatar
Guess it wasnt a boost leak.
Get ready for a noisey ride I have the same set up.
Works great but noisey and after 50k the clutch just started to lock me out at high RPM. Was fine in the begining. Other than that it still grabs 100% just not going into gear at 7.5 - 8k
Old Apr 11, 2008 | 04:46 PM
Veteran: Air Force
great thanks...haha...after I already bought it. Well, if I can make a stock clutch last 32K miles, I should be alright with this beast. What kind of noise? I thought only the twin plate chattered.
Old Apr 11, 2008 | 04:47 PM
Veteran: Air Force
P.S. I did have a random vacuum hose just hangin off...so it helped. Guess we were all right Thanks to everyone!
Old Apr 11, 2008 | 07:06 PM
gsrboi80's Avatar
No not so much chatter. But decel is going to be super audible
No worries though just crank the radio. As for the lockout I cant help you like I said mine was fine forever then just recently no more high rpm shifts for me. I need a 2.4
Old Apr 11, 2008 | 08:37 PM
Lonnie@LMS's Avatar
With your miles it may be more the trans synchros wearing more then the clutch.
Old Apr 12, 2008 | 07:34 AM
gsrboi80's Avatar
Nah tranny shifts like butter. It doesnt grind at all it just locks out at high rpm once the rpm drop a little boom right in. Many have expierienced this issue with the ACT HDSS clutch. Oh well no drag racing this season
Old Apr 15, 2008 | 01:20 AM
ohsobaked's Avatar
boost leak prolly
Old Apr 20, 2008 | 11:22 PM
Chonger1's Avatar
Its probably the boost leak. good luck
Old Apr 21, 2008 | 05:17 AM
Veteran: Air Force
Not a boost leak...slipping clutch. Solved with getting rid of the crap stocker.
