Rear driver's side door lock problem
Old Mar 20, 2008 | 05:17 AM
Chemwarrior's Avatar
I noticed yesterday that my rear driver's side door lock won't operate at all when I hit the power lock on the front driver's side door or when I hit the key fob. Anybody have any suggestions on what could be wrong?
Old Mar 20, 2008 | 05:26 AM
philevo's Avatar
Check the wiring to the door... I had a problem with my side view mirror it wouldnt work, I checked the wiring and it was loose.
Old Mar 20, 2008 | 09:46 AM
Thanks. I'll check that.
Old Mar 20, 2008 | 09:49 AM
DeeezNuuuts83's Avatar
...and if that fails, 5 year/60k mile bumper-to-bumper warranty comes into play.
Old Mar 20, 2008 | 09:56 AM
That is very true and trust me that was one of my options, but unfortunately all of my stock parts are in Tennessee and I am currently in a TDY status in Atlanta, GA. Thankfully it is just me driving around in the car so it isn't too much of a problem.
Old Mar 20, 2008 | 10:02 AM
^ Unless you have new doors and stuff, I wouldn't worry too much about not having stock parts. I doubt they'd deny warranty work on a door lock for mods, plus I'm not sure if they'd actually document mods for work like this.
Old Mar 20, 2008 | 10:06 AM
rcheung's Avatar
Does the power window work on that door?
Old Mar 20, 2008 | 10:33 AM
You might be surprised. I've heard some horror stories and just don't want to take the chance. I'm sure you can see my point.
Old Mar 20, 2008 | 10:35 AM
That's a good question. I didn't check that out. I'll have to do that once I get off of work. Thanks for the suggestion.
Old Mar 20, 2008 | 10:43 AM
Yeah. But I'm sure some research on this site will inform you of some of the reasonable and unreasonable dealerships near you.
Old Mar 20, 2008 | 10:50 AM
I went outside to check to see if the window went down on that side and it does go down. I did a quick look under the dash to see if any wires had come loose and I didn't see any. Does anybody know if that window is powered by a lone fuse or does the fuse power all the windows?
Old Mar 20, 2008 | 12:15 PM
BigEasy0420's Avatar
Mine did that for awhile intermittently. My dealer under warranty just removed the wiring connector in the driver side kick panel because a short developed due to moisture corrosion and I couldn't turn the parking lights off. I haven't had a problem with that door lock since the dealer removed the factory harness connector and soldered the wires together. I couldn't tell you if the power locks to that door sourced power from that connector, it may be just coincidence that I haven't had a problem since then.
