@#$%*&$@# !!!! Icp
Old Mar 21, 2008 | 08:19 AM
06MRV8Killer's Avatar
@#$%*&$@# !!!! Icp
Let me say first, yes I know there are plenty of threads on this but I have to vent.
For the third time in a week I have blown a F***ING ICP pipe off my car. I got it fixed once by 4WS who did it in record time and it blew again only because the coupling was too short. So I fixed it myself yesterday and made sure the coupling had a good inch on each side of the LICP and the IC and put 2 tbolt calmps on the LICP side and BOOM it goes again at 2am last night.
I had to drive 35mph for about 10-15 miles which sucked major @ss. I tried to do the hairspray thing yesterday but it didnt get all tacky so I dont think I had the right type of hair spray I think rubber cement would be better but then be a B!tch to take apart.
Has this happened to anyone repeatedly before? Was it the same pipe that kept blowing off or since you secured one solid did another on pop off? I will findout later today what happened when I rip my car apart again.
Any advice would be greatly appreciated.
Old Mar 21, 2008 | 08:22 AM
meld's Avatar
what kind of pipe is it? is the lower or upper one? Stupid question but is the pipe beaded?
Old Mar 21, 2008 | 08:24 AM
ROAD RACE VR-4's Avatar
Are the intercooler pipes beaded?
Old Mar 21, 2008 | 08:26 AM
TTP Engineering's Avatar
T bolt clamps suck.
Old Mar 21, 2008 | 08:27 AM
I have the Fujita UICP and Injen LICP, it was popping off the LICP on the IC side before but since I cranked the tbolts on it yesterday I probably popped one off somewhere else.....
Beaded, what do you mean?
Old Mar 21, 2008 | 08:28 AM
Originally Posted by TTP Engineering
T bolt clamps suck.
So what do you recommend?
zbomb's Avatar
T bolt clamps suck.
What do you suggest as a better alternative?
Old Mar 21, 2008 | 08:32 AM
Chemwarrior's Avatar
I have the PPI licp with T bolt clamps and have had no problems thus far. Here's knocking on wood.
meld's Avatar
Beaded meaning there is a raised lip around the circumference of the pipe. Also you might have tightened it TOO much and not the pipe is not completely round anymore thus causing an insufficient seal which in turn causes the pipe to pop off.
Old Mar 21, 2008 | 08:33 AM
meld's Avatar
also take some alcohol / brake parts cleaner to the coupler and pipes and make sure there isn't any grease or oil on the surfaces
Old Mar 21, 2008 | 08:36 AM
Evo9tunerz's Avatar
Mine popped off at least 5 times. I used hairspray and I bent two notches on the end of the licp to hold the coupler. This didn't affect the performance at all. After that it's been on for over 6 months now and still boosting 23 psi.
djtmotorsports's Avatar
I strongly recommend stainless "liner" clamps with the stainless screw.
I use the Breeze brand clamps on a regular basis and have never had a clamp related issue.
Darin
Old Mar 21, 2008 | 08:39 AM
philevo's Avatar
you could try these:
http://vibrantperformance.com/catalo...685cc86b5c9df4
Old Mar 21, 2008 | 08:40 AM
I didnt tighten it that much but I will check to make sure today.
Good point I should have thought/done this before.
Darin
I will look into this, nothing suck smore than pulling the MAF and driving slow as fug all the way home.
Thanks everyone so far, anyone else?
Old Mar 21, 2008 | 08:42 AM
Originally Posted by philevo
I cant believe I havent thought of that yet either after drooling over AMS' time attack car which had them....
How do they work you have to drill the pipes?
