evo twitchy at high speeds
Old Mar 26, 2008 | 02:06 PM
yooyooyoo's Avatar
twitchy braking in a straight line? go back to the stock alignment. or get it realigned to the stock alignment.
Old Mar 26, 2008 | 02:21 PM
4cdndctn's Avatar
To answer your question, 2 likely culprits...
1 - you hit your brakes which loosened up the rear end and the road is crowned/has ridges so the light rear end followed the pavement.
2 - Your rear toe is set out and upon the suspension decompressing, your body followed the tire.
Either way, get an alignment with 0 toe and test it again (try to test at lower speeds when on a public road).
Old Mar 26, 2008 | 02:58 PM
Oki Panoki's Avatar
your explanation sounds really good, thats what i was thinking but a little dumbed down
Old Mar 26, 2008 | 03:02 PM
pureEvo10's Avatar
lol i raced an sl 500 benz doin 120 today
Old Mar 26, 2008 | 03:33 PM
EvoTech's Avatar
In the early days at the track I noticed the car was quite twitchy under hard breaking at high speeds. Believe it or not the APR splitter actually helped settle it down a lot. There was a high pucker factor at 120 MPH entering turn1 at Pocono off the staightaway. Much better now.
Old Mar 26, 2008 | 04:01 PM
chrisevo8's Avatar
I would have to agree with what the others are saying and get a good alignment. I dont have any problems at all at that speed (on the track of course).
Old Mar 26, 2008 | 04:12 PM
ApacheFixer's Avatar
Im really impressed with my evos high speed stability. Ive taken it to 14.0 and it felt rock solid. Back when i had my Eclipse GT anything above 13.0 was scary, the front would start to lift and the steering would get light.
Old Mar 26, 2008 | 05:26 PM
grillpt's Avatar
I know around me a lot of the roads are "crowned" really bad causing the rear to get very squirrely under heaving breaking.
Check your tire pressures just to be safe.
Old Mar 26, 2008 | 08:13 PM
sleepyS14's Avatar
haha if that happened to me... i just blame the twitching on i-95 and NYC roads. they're hell on a car. damn nj turnpike
Old Mar 26, 2008 | 08:26 PM
porsherules911's Avatar
got to love roads around here
Old Mar 26, 2008 | 08:43 PM
Solo II Evo's Avatar
Tires for one.. I just took off my Cooper snows and put on a new set of A046s... holy crap. The snows were so scary at higher speeds.
Another thing, as someone else said, an alignment is some of the best $ you'll spend. A good one, not a 'pepboys' alignment. I got -1.5 camber G -1.0 R and 0 Toe rear and 1/16th toe out front.. made a huge difference..
Old Apr 23, 2008 | 03:33 PM
jutilat's Avatar
alignment + wheel balancing
twitchie
Jan 31, 2013 12:54 PM
bchappy
18
Aug 16, 2012 01:27 AM
lan_evo_mr9
Sep 6, 2009 08:39 AM
Driver46
18
Mar 16, 2009 04:56 PM
gandalf
Nov 11, 2008 06:40 PM
