ok. i took my car to the dealership they dont know whats wrong with it.
Old Apr 1, 2008 | 01:00 PM
RevMoto's Avatar
It is 100% the clutch. It first starts slipping higher gears because they require more load. This is common for all evo's to have their clutch's go. Mine went at 14k miles. I just replaced it. The dealership said its not because you are gonna try and have them warranty it which they will never do. Order a clutch.
Old Apr 1, 2008 | 01:06 PM
tnhockey's Avatar
hahaha "costco gas"?? i work there...and its bp gas. of course in illinois we have 93 at our costco pumps...but still, its not like its terrible quality gas. they guys at ur dealership seem to have a very funny uhh...retardation.
Old Apr 1, 2008 | 08:35 PM
jlee's Avatar
thanks for all the advice. yeah im goin to take it to another shop and have them check it out sometime this week.
if i replace it with a act clutch would the dealership void my warrenty?
Old Apr 2, 2008 | 12:01 PM
Gdog87's Avatar
I bleieve its a clutch also but it could be the transmission itself...meaning the forks on the gears arent moving on all the way and are either bent or loose...but id try fixing the clutch because its a cheaper option then if that doesnt work youve got an internal transmission problem
Old Apr 2, 2008 | 12:10 PM
Wicked E's Avatar
Do my clutch test. It's easy and safe...
1) Park the car on a flat surface
2) Pull the E-Brake as tight as you can
3) Put vehicle in 5th gear
4) Slowly let go of the clutch
5) If RPMs drop then the clutch is fine
or
6) the RPMs rise or don't drop much, clutch is slipping
Cheers-
E
Old Apr 2, 2008 | 12:33 PM
boozeup&riot's Avatar
or
Cheers-
E
This is good advice but question: if you owned an VIII (and I realize he doesn't), couldnt this potentially damage the center diff?
Old Apr 2, 2008 | 12:36 PM
Wicked E's Avatar
You're not forcing the car to do anything to damage any components. All you're doing is placing a little bit of load on the tranny.
Don't take my advice and mash the gas while stationary.
Cheers-
E
Old Apr 2, 2008 | 01:32 PM
Cheers-
E
Ok, but in an VIII, isn't that also placing an unnatural stress on the center diff? Not at all meaning to start an argument, just looking for clarification.
It's not bad advice, I just think nearly the same thing could be done by putting in to 5th and just driving at a low speed. I've heard that pulling your handbrake on an AWD vehicle can destroy your center diff, which is why I ask.
Old Apr 2, 2008 | 02:57 PM
Wicked E's Avatar
No idea, I don't own an 8.
-E
Old Apr 2, 2008 | 03:01 PM
my understanding is that without acd, with the handbrake pulled the car will still attempt to send power to both the front and rear. Having the rear locked up, even at a really low rpm can still torque the rear and potentially cause you quite a bit of headache WRT the center diff and the t-case...but this is just my understanding. Anyone who knows for certain - please kick down the knowledge.
Old Apr 2, 2008 | 03:05 PM
Wicked E's Avatar
Realize that you're NOT attempting to send power. All you are doing is pre-loading the tranny.
This advice was given to me by Brad at mellon tuning who has an 8.
Take it with a grain of salt.
-E
Old Apr 2, 2008 | 08:00 PM
ImJoey's Avatar
Well Ive E-braked through a few turns and the evo loved it
My car does exactly what youre describing.My clutch is bad......Your clutch is bad too.Hope youre ready to dump $675 for clutch+$500ish on install.
Listen to everyone here when they tell you to avoid dealerships at all costs in the future.Even general maintence scares me at mitsu thus I never returned warranty valid for 14k more and all.
Old Apr 2, 2008 | 08:58 PM
el producto's Avatar
This is their way of telling you "they have no experience doing clutches and cant afford to fudge up your car"
Old Apr 2, 2008 | 09:00 PM
chrisevo8's Avatar
sounds like clutch to me.
Old Apr 2, 2008 | 09:25 PM
mitsubishifreak's Avatar
clutch slippy
not all dealerships are bad the techs are ok its the crappy service advisers trying to up sell you something.sounds like clutch is out. buy nice act
