Any advice on removing this part? (pics)
Old Apr 1, 2008 | 04:12 PM
damstr's Avatar
Alright well I want to take the shifter arm off my car, but upon closer inspection it appears it might be a little more complicated then I thought.
Anyone here remove this arm before, if so any do's or don't? From what I can see I just disconnect the shifter cables and unbolt the unit from the tranny.
Here are pics of exactly what I'm talking about. (brass colored arm is what I want to take off not the battery holder) Sorry I was using my phone and its hard to get upclose without getting blurry but you get the idea of what I'm talking about.
thanks!
Old Apr 1, 2008 | 04:14 PM
ak47po's Avatar
Whats the reason for removing it?
Old Apr 1, 2008 | 04:26 PM
urslo4n8's Avatar
i was curious myself??
Old Apr 1, 2008 | 04:32 PM
damstr's Avatar
I have reason to believe its cracked and want to take it to the dealership to get it replaced. I tried describing it to them and they still didn't know what in the world I was talking about.
I tried showing the guy while I was there but when you have the battery and everything else in you can't even see it, and I don't feel like paying the dealership to work on my car who I already don't trust.
Old Apr 1, 2008 | 05:33 PM
ak47po's Avatar
Control housing #15
Unless you what your doing let the dealer take it out.
Old Apr 1, 2008 | 05:42 PM
damstr's Avatar
Originally Posted by ak47po
Control housing #15
Actually I'm talking about the arm that sits ontop of part number 15. (above the black rubber guard)
Old Apr 1, 2008 | 05:43 PM
ak47po's Avatar
Looks to me like one whole unit.
Old Apr 1, 2008 | 05:46 PM
damstr's Avatar
I'll have to take a better look at it tomorrow its appears that you are correct.
Old Apr 1, 2008 | 05:50 PM
StreetEvo's Avatar
Ak is correct. The arm youwish to remove is part of the shift control mechanism. It is a single unit(just rebuilt a tranny for one of my boss's race evos).
Old Apr 1, 2008 | 05:51 PM
damstr's Avatar
Alright well how difficult is it to take out and put back in?
Old Apr 1, 2008 | 06:03 PM
cssaddictm4's Avatar
It's not difficult if the tranny is out of the car. Not too sure how hard it is with it in. You have about 3 bolts and it slides out. It is one assembly.
Old Apr 1, 2008 | 06:11 PM
damstr's Avatar
Theres actually 5 bolts holding that in I'm pretty sure unless 2 of those bolts weren't holding that particular part in.
I have a good amount of space to work with, easily could get all 5 bolts out with no problem. The unit could come straight up about 10 inches before it would hit the strut bar. Thats a rough estimate going off my memory.
I don't have to worry about lining anything up right? I saw in that diagram theres a return to neutral spring at the bottom of the unit, I won't have to mess with that will I?
thanks
Old Apr 1, 2008 | 06:15 PM
I believe you just have to keep #16 on its' shaft while putting it back together. From my memory, #13 definitely has to come out to slide the shaft out..took mine apart about 3 months ago.
Old Apr 1, 2008 | 06:19 PM
WTF? Double post with high speed internet? I guess it's just too fast.
Old Apr 1, 2008 | 06:22 PM
damstr's Avatar
I believe you just have to keep #16 on its' shaft while putting it back together. From my memory...took mine apart about 3 months ago.
Interesting, I wonder if gravity will pull #16 off the pin when putting it back down into the tranny or not?
Anyway thanks for the advice man, doesn't sound too bad.
