Does this Evo check out?
Old Apr 3, 2008 | 02:53 PM
gsrboi80's Avatar
Yea thats the main thing man you have to check the car out. I wouldnt even by a bone stock car with out checking it out.
Old Apr 3, 2008 | 02:54 PM
the515's Avatar
the car isn't bone stock though
Old Apr 3, 2008 | 03:11 PM
lysy82's Avatar
first check for any accidents it says in description that is has other title!!!!so before you do anything run carfax on it.
Old Apr 3, 2008 | 03:12 PM
the515's Avatar
Okay. Well first I need someone to help me decide what to look for when i go see it. Can someone help me out with that?
Title is clear: I called the guy and he said that he put it under other title just to remind himself to talk about the odometer. The odometer problem was recorded and repaired correctly
Old Apr 3, 2008 | 03:40 PM
gsrboi80's Avatar
Oops I knew it wasnt stock . I meant I wouldnt even buy a stock car with out checkin it out
FIXED
Old Apr 3, 2008 | 03:52 PM
the515's Avatar
Okay well what should I look for on the car? Ill be looking at it this weekend, I set up plans.
Old Apr 3, 2008 | 04:04 PM
EV0lved's Avatar
look for body damage, interior, underhood, any major differences between it and stock anything and everything that might not appear stock, i dont know how hardcore you are on how stock it needs to be. also check the suspension, brakes, tires, all that good ****, have fun, good luck, and make sure you drive it!
Old Apr 3, 2008 | 04:26 PM
the515's Avatar
Well I dont really care about it being stock, I just want to make sure after a week of driving it the damn wheel doesn't fall off.
Also I talked with the dealer and all the service records and paperwork for the mods have been kept and are available.
Old Apr 3, 2008 | 04:56 PM
gsrboi80's Avatar
Drive it, Check all the fluids,
How does the tranny feel?
How does the clutch feel?
Take it on the highway does it track straight? Vibrate?Creak?Noises?
How are the brakes? Check the pads and faces of the rotors. Do they pulsate under hard braking?
How does it boost? Does it have a boost gauge?
If it was private you could talk the owner into a compression test.
Inspect the tires and wheels. How much tread is left? Any bends or scrapes on the rims?
Inspect under the car. Make the dealer put it on the lift. Is there anything scraped? bent? torn? broken? Leaking? Wet? Doesnt look right?
Inspect the body. How is the paint? Dings? Are all the panels straight and do they line up to one another?
Are there markings on the bumper,fender,door,hood, or trunk bolts signaling that they have been removed before
Its just stuff you need to do buying a used car. 100% used cars can be the best buy you can make. You can save tons of money in depreciation. You need to know what your looking at though
Even if you need to lay out a little green if you dont know cars I highly suggest that you bring somone with you that can do all of the above
Old Apr 3, 2008 | 05:00 PM
the515's Avatar
That is exactly what I needed. You rule
Now what is the whole big deal about this BOV. I read that BOV on Evos are bad?
Old Apr 3, 2008 | 05:16 PM
gsrboi80's Avatar
Im not going to give you everything a quick seach will tell you this. That valve sounds cool but it just doesnt work well with the MAF even recirc
Old Apr 3, 2008 | 05:22 PM
j14mp's Avatar
and its black... u dont want to buy a black evo with that many miles unless its brand new... no offense TB evo guys, but you must agree, if they arent taken well care of, they look like hell. But TB FTW
Old Apr 3, 2008 | 05:33 PM
gsrboi80's Avatar
Ah its only paint
Old Apr 3, 2008 | 05:38 PM
IEXCELR8's Avatar
Just buy this one
https://www.evolutionm.net/forums/sh...d.php?t=319057 24,500
Old Apr 3, 2008 | 05:44 PM
Billy@EnglishRacing's Avatar
it says the car has thousands of extras, ask them to list the first 1000 for you
