lifter tick with 5w 30 oil
Old Apr 14, 2008 | 12:27 PM
lemmonhead's Avatar
I was using mobile 1 10w30, but since the hot weather is starting to come this way in the midwest. I decided to use 5w instead of 10w. Well, all of a sudden 1,500 miles later the lifter tick started. I only hear it at idle.
well needless to say im draining out the oil and putting the 10w30 mobile 1 oil back in.
Old Apr 14, 2008 | 12:28 PM
lords3t's Avatar
5w 30 is better for colder weather.
Old Apr 14, 2008 | 12:45 PM
lemmonhead's Avatar
oops i meant 5w20 not 5w30,
I thought really 5w vs 10w was insignificant in that that is the rating that a pump will flow it at a given temperature rating right?
i thought the 2nd number was more important.
at any rate, im using strickly 10w30 for now on,
Old Apr 14, 2008 | 01:25 PM
mplspilot's Avatar
You sure it's not injectors ticking?
1st number - weight at cold temp. 2nd - weight at operating temp. Higher number - thicker viscosity.
Old Apr 14, 2008 | 01:36 PM
bomjoon's Avatar
^ +1
i use amsoil 0w30 and it runs fine.
no problems.
i think the problem you have is not related to oil yous using.
Old Apr 14, 2008 | 01:47 PM
lemmonhead's Avatar
The thing is if it did that after the car was already warmed up and after a run. I got home and let it idle to cool the oil so i dont cook the turbo and that is when i heard it tick. im not to familiar with the "ticking" phanomanon. I just heard about it. but never had that sound when using 10w30 and its weird how it showed up pretty much immediately after switching to 5w20.
Old Apr 14, 2008 | 01:48 PM
lemmonhead's Avatar
injector ticking is normal during cold starts correct? so im pretty sure its not injector ticking.
Old Apr 16, 2008 | 07:25 PM
Oil Doc's Avatar
5W-20 is NOT Recommended for the EVO.. It needs to be a 30 wgt and Synthetic.. If you are going to stay with Mobil 1, be sure it is Mobil 1 EP.
If you would like AMSOIL, ATM 10W-30 or our Top of The Line, SSO 0W-30
WIX 57092 Filter, MTG for the tranny and SVG for the TC and Diff..
Doc
Old Apr 22, 2008 | 01:43 PM
bomjoon's Avatar
bought some oil thru ^^ bob. 0w30
i like it sofar.
Old Apr 22, 2008 | 02:16 PM
lemmonhead's Avatar
how much for 5 quart of that 0w-30 stuff?
Old Apr 22, 2008 | 03:33 PM
Oil Doc's Avatar
$46.00 plus taxes
Doc
Old Apr 22, 2008 | 04:00 PM
bomjoon's Avatar
It was 90$ somewhat for 10 qt delivered to me.
Old Apr 22, 2008 | 04:55 PM
Oil Doc's Avatar
That would be about right for 2 gal and 2 qts.... $84.75 plus tax
Doc
justboosted02
76
Oct 2, 2019 04:02 PM
mberenis
19
Aug 24, 2016 07:50 AM
nadevo
Aug 4, 2016 07:46 AM
Spoolin4g63
Jun 17, 2015 09:43 AM
Kevin Knight
Jun 28, 2007 03:26 PM
