Creeking noise when engaging gears
Subscribe
Apr 24, 2008 | 08:26 AM
First off, I know things in the cabin will start to loosen & creek over time. However, the noise seems to come from the bottom of the car. It kinda hard to describe exactly where the creeking noise is coming from, either under the pedals or shifter. When I engage first gear and starting moving, I heard the noise then it goes away. As soon as I shift to second, the noise comes back and so on for the rest of the gears. Any idea what's the cause??? Clutch problems???
Reply 0
Apr 24, 2008 | 09:38 AM
Might be your throwout bearing, but seems unlikely because your car is pretty new. How many miles and still on stock clutch?
Reply 0
Apr 24, 2008 | 09:39 AM
Oh and does it do it in neutral while pumping the clutch too? Or only in gear?
Reply 0
Apr 24, 2008 | 10:04 AM
Quote: Might be your throwout bearing, but seems unlikely because your car is pretty new. How many miles and still on stock clutch?
Currently ~13000 miles and still on stock clutch.
Reply 0
Apr 24, 2008 | 10:06 AM
Quote: Oh and does it do it in neutral while pumping the clutch too? Or only in gear?
Let me try & get back to you. Thanks for your help!
Reply 0
Apr 24, 2008 | 11:14 AM
Quote: Let me try & get back to you. Thanks for your help!
Sure np! Yeah if it does it in neutral too then it sounds like your TOB. I wouldn't really go through all the effort to change only because of the sound. Just wait until your clutch goes out and change it then.
Reply 0
Apr 24, 2008 | 11:34 AM
My car is doing the same exact thing and I just recently had the clutch replaced. Everytime I push the clutch pedal in, it makes that creeking sound.
Reply 0
Apr 24, 2008 | 12:55 PM
great info slow evo. Mine is doing the same thing, but I have 59K on my stocker
Reply 0
Apr 25, 2008 | 10:22 AM
Quote: Sure np! Yeah if it does it in neutral too then it sounds like your TOB. I wouldn't really go through all the effort to change only because of the sound. Just wait until your clutch goes out and change it then.
Doesn't do it in neutral, only when I depress the accelerator.
Reply 0
Subscribe
