What do I need to make my EVO8 faster?
Old Aug 8, 2003 | 07:38 PM
GREDDY's Avatar
I'm new here with an EVO8. I came from a Turboxs stage 2 WRX. I want to get recommendation from you guys on how to make this thing faster.
Old Aug 8, 2003 | 07:41 PM
ZapcoLancer's Avatar
Well to keep you from being slow get a "no fat girls inside" decal on your window. Should keep your speed from getting "weighed down".
This topic was discussed on a few occassions I am sure. Try running a search for this, you could get more than 1 thread most likely.
Old Aug 8, 2003 | 08:08 PM
TRDHarrier's Avatar
Air fuel tuning device since it runs too rich. I have read so much about it and I do feel I am a little more confident than usual now. Get urself a useful air fuel ratio gauge not those x'mas lights from autometer. I believe that the GReddy one is good enough. You should also get yourself an EGT as well to determine if your exhaust temperatures are too high or not. Then, bring it to a dyno or a flat open area where u can fine tune with an air fuel device such as SAFC or SAFR or EManage etc. But since you need to weld a bung in the downpipe or exhaust, get urself an aftermarket exhaust before doing so. You should get an intake (to free up some air going in, unneccessary but sounds nice and do give u maximum 4 hp to the wheels), downpipe, cat-delete, catback exhaust or just a turboback exhaust. Add a boost controller and set at 20psi starting from 3500 to redline and ur done You also need a better BOV btw... This is my goal for my Evo
Old Aug 8, 2003 | 08:11 PM
GREDDY's Avatar
TRDHarrier, thanks for the reply. With that upgrade, what power level should I be?
Old Aug 8, 2003 | 08:58 PM
evo1's Avatar
Re: What do I need to make my EVO8 faster?
Electronic or manual BC
S-AFC or GReddy E-Manage. HOWEVER, skip the EBC if you have access to a full custom tune on a dyno with wideband o2 -- such as a reflash or piggyback set-up. For instance, I plan to run an S-AFC & EBC until a custom tune becomes avail. in my area (Ecutech software is being developed for evo)
3" TURBO back exhaust (remove cat)
BOV
272/264 CAMS
Even without the cams, this set-up (with MBC & S-AFC) will cost between $1500-2500 for approx. 280 whp! You can expect very low 1/4 mile 12's or possible high 11's with the cams ... and mid to high 12's without.
Old Aug 9, 2003 | 05:46 AM
maki's Avatar
GREDDy SAFC, SAFR, EManage, intake is crap, dont buy it. If you want more power you need a turbo kit, good ecu, cams and a downpipe with free flowing exhaust.
Buying crap you dont need is neither smart, nor cheap. Just my .02cents
Old Aug 9, 2003 | 08:53 AM
TRDHarrier's Avatar
u make less power if u run too rich....that is why our engines are rated 271 hp while the jdm evos are at 300
Old Aug 9, 2003 | 10:38 AM
maki's Avatar
harrier youre absolutelly right, but everything can be done with one good ecu. hks fcon vpro, apex power fc, motec.
Old Aug 9, 2003 | 07:59 PM
GREDDY's Avatar
Thanks guys, if I can even run 12's, I'd be happy.
Old Aug 9, 2003 | 08:01 PM
GREDDY's Avatar
Ok, this is what I need right?
3" TBE
Engine management
BOV
Boost controller
And I should be able to run 12's?
Old Aug 10, 2003 | 04:12 AM
SHIFTY's Avatar
Yes and I think it has been done.
ryans1000
Feb 22, 2011 10:12 PM
Evolutionary8
21
May 24, 2010 04:08 PM
k20toEVO
Aug 2, 2009 01:42 AM
Mrbobcat
May 12, 2008 11:51 AM
rallyred1234
16
Apr 13, 2008 10:24 PM
