donut?
Old May 6, 2008 | 05:02 PM
elphalba's Avatar
donut?
just put in my megan tbe . i bought it used but when i bolted up the downpipe i got an exhaust leak . i reused the original donut gasket and spring bolts and it definitly leaked . then in desperation until i find a fix i used honda bond to seal it temporarly and regular bolts and tightened the shhh out of them.
i gues my question is when u buy a tbe does it come with a specific donut gasket and spring bolts or do most people reuse the old ones?
Old May 6, 2008 | 05:06 PM
Protostar1's Avatar
I have a buschur tbe and the downpipe bonds directly to the o2 housing, as in no gasket. My gasket was pretty bonded on there originally and I tore it up pretty good on the removal... Oh and be careful with over tightening regular bolts on the housing, I have heard cracking is possible there.
Old May 6, 2008 | 05:13 PM
Extas's Avatar
When I got my Megan TBE it came with a new donut gasket. The OEM spring bolts did not fit so I had to buy some new standard bolts.
Old May 6, 2008 | 05:14 PM
elphalba's Avatar
was it the same gasket (oem)
Old May 6, 2008 | 07:24 PM
evo150's Avatar
for the megan downpipe, you re-use the stock donut gasket but dont use the stock spring bolts (bought new megan supplied 2 new regular bolts for the install). if the bolts you have installed now in place of the spring bolts thread correctly and are the right length you should be good, just make sure to torque them to the correct specs; downpipe to o2 housing should be torqued to 37 ft/lbs , and downpipe to cat should be torqued to 37 ft/lbs also.
Carnifex
Jun 22, 2015 09:29 AM
GTijoejoe
Oct 10, 2011 07:06 PM
BEISSEN
Oct 22, 2010 09:02 PM
CFaber
48
Jan 28, 2006 08:00 PM
fatalbert69
Jun 23, 2005 05:10 PM
