what the heck
Old May 22, 2008 | 11:30 AM
  #31
mp5999's Avatar
btw, I think it might void his case since he took the car out of there.
Old May 22, 2008 | 11:32 AM
  #32
Tim@AMSperformance's Avatar
Originally Posted by 9sec240
I am going to bet money that the small tab that is on the large factory ground cable that attaches to the drivers side strut tower with a bundle of other ground wires is not hooked up.
I THINK IVAN IS ON TO SOMETHING PLEASE CHECK WHAT HE IS STATING. IVE SEEN THIS BEFORE!!!!
Old May 22, 2008 | 11:33 AM
  #33
mp5999's Avatar
also , did you get anything in print about what they did, and especially what you were told????
Old May 22, 2008 | 11:37 AM
  #34
mp5999's Avatar
you know , the more I think about this crap the more it really pisses me off. You realize that for the price of the part and the labor- and I am talking what THEY actually have into it- it would have been pennies compared to what they rake in just in a week. They could have came off like the good guys , took care of it, ate a couple of bucks, and then had a happy customer that would have spread good words about them. Instead they want to be tight wad a-holes and now have people that will spread bad stuff about them, scare off potential customers, and have posts like this that will be here on the internet forever to haunt them.
bastards!
Old May 22, 2008 | 11:42 AM
  #35
Chayevo's Avatar
get lawyer
  #36
tsdchodan's Avatar
They aren't called stealerships for nothing.
Old May 22, 2008 | 12:09 PM
  #37
steinvb12's Avatar
I think some of you are jumping to conclusions.
If the cam sensor is bad, and the wires and wire harness started smoking at the dealership...Couldn't this of been the same problem that caused the original cam sensor to go bad (or cause a problem) in the first place?
How is this the dealerships fault then? This same problem is the reason the cam sensor went bad in the first place. I'm not saying this is the case for sure, but it certainly could be. Just because it wasn't smoking before doesn't mean it wasn't shorted or going bad before.
But everyone seems to blame it right on the dealership......wow......
Old May 22, 2008 | 12:23 PM
  #38
slicedbreadno2's Avatar
Damn this all sounds like a huge mess.
Old May 22, 2008 | 12:37 PM
  #39
Boricua_Evo's Avatar
Something I thought might lead you to the right track! This has been around for a while!
SEMA is the Bomb! Hope this helps!
Warranties and Modifying Your Car
Old May 22, 2008 | 03:42 PM
  #40
Scottr126's Avatar
Nobody wants to listen....
Old May 22, 2008 | 11:07 PM
  #41
BULLET8071's Avatar
agreed..verify customer complaint..cause/source/test/replace/recheck...since the service advisor, AND service manager most likely havent seen any previous history with the vehicle every being serviced, they just brushed this poor guys car problem aside.. i know this cause my last 4 dealerships ive been working at, have done the same as far as management goes
Old May 23, 2008 | 03:35 AM
  #42
PHDoc19's Avatar
Yeah, but the first thing the dealerships do is blame the owner and what they've done to the car. It's a vicious cycle.
Old May 23, 2008 | 06:58 PM
  #43
Ivan@AMS's Avatar
Let me try to make a suggestion once again.
When you delete the ground strap lug going to the drivers side strut tower (ie as many do when they put a small battery kit) you run the chance of burning up your harness. We have seen this several times on the Evo. It appears that if the ground lug is removed, electricity finds another path to ground which ends up being in the harness that goes to the cam sensor.
So the question is... Was the ground lug hooked up on the car or not?
Old May 23, 2008 | 11:20 PM
  #44
EvoHung's Avatar
Before we go further I believe this question must not be ignored. The answer to this question might make all of the differences.
Old May 24, 2008 | 07:17 AM
  #45
DESERTEAGLE50's Avatar
i'm going to look but i dont think there is a ground on the strut tower on a ix.
