Anyone know how to get better gas mileage?
Old May 25, 2008 | 12:40 AM
W_evo8's Avatar
Buy A Prius?
Old May 25, 2008 | 12:48 AM
krazirob's Avatar
on your map you can adjust your fuel trims during cruise......so now i run around 15.5 afr when im just cruising, and then everything goes to normal when i get on it
noticed a big difference
Old May 25, 2008 | 01:21 AM
importjake00's Avatar
stay out of boost
Old May 25, 2008 | 02:59 AM
SunKren's Avatar
Originally Posted by importjake00
stay out of boost
The fun part about evo is that you can really turn evo to 4 door sedan. It is possible when you shift before 3k rpm where the turbo does not boost at all. Well that is the city scenario. Highway is about the same, don't play that much with gas pedal when you don't need or have too. I tried my MR before when I was going to Vancouver BC, turned out I got like 24mpg or somewhere there on highway/freeway.
Old May 25, 2008 | 05:27 AM
Mellon Racing's Avatar
quite a few of my customers reported better gas mileage after a tune...
I just checked mine and it's 22mpg with city/highway daily driving...not bad for a 500awhp daily driver with twin walbro fuel pumps, 1000cc injectors and some spirited driving here and there
stock ecu/mas
Old May 25, 2008 | 06:37 AM
njboy's Avatar
Sad days for car enthusiasts but then again the up side is that at some point these high prices will keep more people off the roads. :-)
Oh drive slower and don't spool the turbo so much and one can get mid to high 20mpgs. Not easy but possible.
Old May 25, 2008 | 07:16 AM
MR Turco's Avatar
some normal bolt ons will also help improve gas millage. I noticed an improvement with a downpipe, hfc and drop in filter. highway i get 25mpg, strickly around town i will get 19, but i also dont drive the car nicely. A tune will help if you are in open loop otherwise you will be running closed loop fueling which isn't affected by a tune. leaning out open loop will have negligible gains since you aren't usually in boost for very long. Also try keeping the car under 80mph on the highway.
Old May 25, 2008 | 07:25 AM
keevo54's Avatar
55-60 on hwy and stay off boost
Old May 25, 2008 | 07:32 AM
FJF's Avatar
FJF
The quicker my car gets, the worse the fuel economy. Most likely, this is due to my opening the taps at every opportunity. I see ~15-18MPG, all city. As mentioned, driving conservatively and staying out of boost saves fuel, as dull as that may be.
Old May 25, 2008 | 07:48 AM
Chemwarrior's Avatar
This isn't entirely true. There are ways to program your ECU to switch to open loop while you are actually in closed loop. This will in turn increase your mpg.
Old May 25, 2008 | 09:53 AM
Nuked's Avatar
Big turbo. Mileage will def go up being that you can cruise the highway/around town and never touch boost. It will be faster too
SQ
Old May 25, 2008 | 10:05 AM
lancerMRguy's Avatar
Stay off boost. I am hoping to get a tune soon cause around town I am barely getting over 200 to a tank and its killing me. Highway I can pull about 275 and then some but I never want to chance it.
3_diamonds_'s Avatar
why you people always make it look like people with expensive cars not suppose to care about gas.people who drive benz and bmw also want to save on gas. probably he just prefers an evo over a corolla and nothing is wrong with that.
Old May 27, 2008 | 07:47 AM
mhgsx's Avatar
It comes down to the fact that if the extra $10 per fillup is putting you over the top, then you made a poor decision in buying a car this expensive. It has NOTHING to do with being an Evo.
Old May 27, 2008 | 07:49 AM
JJsEvo8's Avatar
Id say 2k shifts. And drive 55 on the highway.
