Aftermarket Power Steering Fluid Take 2
Old Jun 12, 2008 | 07:17 AM
wickdaddy's Avatar
Alright.. after looking through 5 pages of a 'power steering' search, not one thread had an aftermarket power steering fluid answer..
i know, 'go to the dealer and pick up the oem fluid' is the typical answer, but I cannot get up to a dealer, my fluid is low, the steering is squeeking a bit, so before I end up with a larger/costly pump problem, I need to get some more fluid in there..
should I just get the most expensive ATF fluid? or what is recommended? I don't need to break anything as this is my dd.. thanks in advance
Old Jun 12, 2008 | 07:20 AM
Curt@MrLed's Avatar
Former Vendor
Owners manual say what it takes?
Old Jun 12, 2008 | 07:29 AM
wickdaddy's Avatar
ya Genuine Mitsubishi Power Steering Fluid =/ there has to be something aftermarket that will work just as good
https://www.evolutionm.net/forums/sh...86&postcount=3
Old Jun 12, 2008 | 08:22 AM
thatguybryan's Avatar
You can probably run to your local Autozone and they will have Mitsubishi "TYPE" which will be fine for now.
Old Jun 12, 2008 | 03:59 PM
edmundo's Avatar
Valvoline Syn Power, power steering fluid. Compatible with most brands. I used it in my car without untoward effects.
Old Jun 13, 2008 | 10:56 AM
wickdaddy's Avatar
ended up picking up Prestone.. seems to have pretty much removed the squeaking..
St1g
Aug 7, 2015 02:24 PM
Houstonsc300
Mar 21, 2011 07:01 PM
xLancer_Beastx
Sep 12, 2010 12:59 PM
wntanEVO
Nov 8, 2009 03:36 AM
memo3
Apr 18, 2004 06:03 PM
