Used to be a modded Evo?
Old Jun 17, 2008 | 09:22 AM
vanilla2's Avatar
Is there any way to tell what the car has been tuned for?
Old Jun 17, 2008 | 09:31 AM
04gsna's Avatar
if he has a cable he can read his rom and send it to one of us
Old Jun 17, 2008 | 11:19 AM
92gsxbaltimore's Avatar
thats whack. Is it running poorly? Check compression and go from there
Old Jun 17, 2008 | 11:22 AM
fame118's Avatar
looks like meth
Old Jun 17, 2008 | 11:44 AM
teribble's Avatar
so if it was running meth, what would be the down side of that? Just being driven hard?
Old Jun 17, 2008 | 12:45 PM
JJsEvo8's Avatar
Man that blows hard, i would def take it back and get it fixed or ur $$ back
Old Jun 17, 2008 | 12:57 PM
DocCola's Avatar
i would be pissed beyond words if a dealership sold me this car. please tell us it wasnt a mitsu dealership?
Old Jun 17, 2008 | 01:37 PM
whooshski's Avatar
It definetly looks like meth, but that doesnt exactly mean that the car is doomed. Have some one check the car out, compression etc..
Old Jun 17, 2008 | 02:21 PM
tnhockey's Avatar
that sucks man. i didnt find anything as extensive as nitrous or meth previously hooked up, but i did buy my car used from mistu dealer that was "stock" but after putting on an intake i found lots missing bolts and other indicators that it had been modded...my 2 step was set higher and mine also revs to 8k. good luck with ur car tho.
Old Jun 17, 2008 | 02:33 PM
jmelocik's Avatar
I am leaning towards meth with out seeing the holes in the trunk you are talking about. On the plus side if you need an upper inner cooler pipe you should be able to find one cheap on here if you just want stock! As stated earlier, pull the IAC motor and see if the tip is burned or shows any evidence of heat damage. If it does PM me and I will sell you one a lot cheaper than the dealership will.
Josh
Old Jun 17, 2008 | 03:01 PM
wreckless969's Avatar
Is there a thread somewhere that tells all the different things to look for to find out if your car has been modded previously? Iv bought an 05 VIII that Im waiting to be delivered. Its supposed ot be stock but it has a Defi boost gauge in it.
This thread has me a little worried. So if anyone can give me a few pointers or point me to a thread that can thatd be great.
Old Jun 18, 2008 | 06:23 AM
slvrr's Avatar
I don't understand why you guys are saying "thats whack or thats shady" when he bought it it had a boost controler and stuff so it was obviously modded. I don't see what the problem is. Most likely the previous owner parted the car out and traded it in. Why would the dealer be at fault here? It sounds like a consumer that didn't do his homework to me. Most of the people on here are awfully quick to judge....
Old Jun 18, 2008 | 08:34 AM
Master Evo8's Avatar
the car runs great with no problems since the day i got it, will this car be scrap if it was running meth?
Old Jun 18, 2008 | 08:35 AM
i just had a boost gauge installed and its running 19 psi
Old Jun 18, 2008 | 09:27 AM
Do a compression test. Nobody will be able to give you anything but guesses until you find out if your engine is still healthy.
