i need 400-450 hp
Old Jun 24, 2008 | 04:51 PM
mrep32u's Avatar
i need 400-450 hp
hey guy's wassup? i have an 06 evo9 and i was wondering what i would need to achieve 400-450 hpi have about $4000 budget i use the car as a dd so i need it to be reliable please any suggestions???
Old Jun 24, 2008 | 04:52 PM
RyeLou's Avatar
$4,000 will buy one hell of a search.
Old Jun 24, 2008 | 04:55 PM
JDMCT9MR's Avatar
Are you talking about 400-450 whp or at the flywheel?
Old Jun 24, 2008 | 05:00 PM
mitdrx's Avatar
You are a funny fella
06MRV8Killer's Avatar
Check out my sig and there is your answer...
Old Jun 24, 2008 | 05:03 PM
Tnnrx7's Avatar
Well for one your sig doesn't say **** besides brand names. Doesn't show any specific parts or anything. BTW, you spelled Invidia wrong, and I'm assuming thats your O2 housing
Old Jun 24, 2008 | 05:13 PM
TheoryVIII's Avatar
Any of the gurus can correct me if I am wrong but i would say:
TBE, intake, a good set of cams, fuel pump, and a tune and i guess giving the cams and the tune 400 to 450 is doable
Old Jun 24, 2008 | 05:18 PM
TURBevO8's Avatar
Dont forget a MBC set to around 22psi. Add that and I would say 380ish whp is doable.
Old Jun 24, 2008 | 05:19 PM
Tnnrx7's Avatar
If you get a GOOD TBE, with test pipe, and a GOOD intake (drop-in I recommend WORKS) with everything else mentioned, you should be very close if not breaking the 400hp mark.
Old Jun 24, 2008 | 05:22 PM
EatSleepBoost's Avatar
intake, tbe, fp green, cams, tune
Old Jun 24, 2008 | 05:25 PM
evo_what's Avatar
first you need to decide if you want 400-450 at the flywheel or 400-450 at the wheels. 400-450 at the flywheel can be had with bolt-ons, cams and a tune. if you want 400-450whp then in addition to the mods i mentioned you'll need a turbo kit (30R or so) an intercooler, and fuel system. good luck.
-Chris
Old Jun 24, 2008 | 07:20 PM
djsgtrip's Avatar
Stock turbo with boltons and cams will get u 400 crank hp on pump gas (330-360 whp). If you want 400+ whp on pump, then you need to step up to at least gt3076r / 50 trim garrett / Fp green . These turbos can make just about 400-425 whp on pump at near limit. If you want 400+ whp all day on pump with room to grow, then go with GT35r / buschur 3065 / PT61 /HTA 3076...
Old Jun 24, 2008 | 07:27 PM
ddillard424's Avatar
stock turbo fully bolted with METH and a 4WS tune!!!!
Old Jun 24, 2008 | 07:46 PM
Footballav81's Avatar
like a lot of ppl here are saying full bolt on's cams, cam gears, meth, with a good tune will get you at 400hp on a stock turbo if you wanna get 430hp-450hp get a green with another good tune on meth or race gas
Old Jun 24, 2008 | 07:53 PM
mrep32u's Avatar
to the wheels
chill with all the acronims im new to this car i need the names of parts
tune!!!!
a good source told me the same thing
