A bunch of water dripping from under glove box.
Old Jun 27, 2008 | 10:04 AM
W_evo8's Avatar
Question A bunch of water dripping from under glove box.
I'm guessing its from the A/C but I still haven't been able to pnpoint it. Just wondering if this is a common thing. Has this happened to anyone else? It's an 05 evo 8.
Old Jun 27, 2008 | 10:07 AM
Barn_13's Avatar
your A/C drain is probably clogged..if you can get under the car and find the drain hose shoot some air into it and see if a bunch of water comes out then that would be your problem. Being a former Honda tech that was common on hondas.
Old Jun 27, 2008 | 10:08 AM
pltnym's Avatar
same thing happened to my IX. took it back to the dealership & got it fixed. it hasn't happened since. my guess is it's the a/c cause thats the only time i noticed it was dripping.
Old Jun 27, 2008 | 10:09 AM
azturbolancer's Avatar
yea its common on pretty much every car
Old Jun 27, 2008 | 10:52 AM
Tom W's Avatar
i happened to my moms Lancer ES, its common
Tom
Old Jun 27, 2008 | 11:51 AM
Craig King's Avatar
Was it actually leaking into the car you mean? Or under the car, where the glovebox was?
Old Jun 27, 2008 | 11:54 AM
zeus1's Avatar
had the same thing happen to me. for some reason it only occured once and that was it.
Old Jun 27, 2008 | 11:55 AM
Kurt's Avatar
It happened to my old OZ 3 different times. Here is how I fixed it on the third and final time. I got some rubber tubing that was slightly larger than the drain and attached it to the drain. The other end of the tubing was duct taped to a shop vac. I turned the A/C on full blast and turned the vac on and watched all the crap go through the tubing. I left the shop vac on until I saw no more dirt in the tubing.
Old Jun 27, 2008 | 11:56 AM
ddfelix5494's Avatar
Yeah I checked that the other day on my evo and chalked it up to the a/c
Old Jun 27, 2008 | 01:49 PM
holler mcdollar's Avatar
hmm. never experienced this, but then again i never use my AC.
Old Jun 27, 2008 | 02:05 PM
scheides's Avatar
EvoM Moderator
LOL my wife had a 2002 Lancer ES and the thing FILLED the freaking passenger side floor with like 3" of water! Turns out there were a bunch of leaves stuck in teh A/C drain, right above the rear motor mount on the firewall. Some compressed air in there and then get the heck out of the way!!!
Old Jun 27, 2008 | 02:11 PM
MitsuJDM's Avatar
Werd. I'm currently a Honda tech. Once May-June rolls around, there are MANY complaints of wet carpets.
fst8nuff
Aug 10, 2016 09:33 PM
Womb Raider
May 16, 2016 01:36 PM
Cyber
Apr 21, 2016 03:36 AM
likeker23
Apr 7, 2016 01:20 PM
InitialDae
Jul 3, 2015 12:31 AM
