Seibon Hood Causing A/C Problems??
Old Jul 1, 2008 | 10:18 AM
mostH8D's Avatar
prolly not reported....
Old Jul 1, 2008 | 10:59 AM
mx4life85's Avatar
True, didn't think of that. Nothing else is bent though? And it seems like its bent in the exact spot the hood comes down at.
Old Jul 1, 2008 | 11:45 AM
mostH8D's Avatar
fat model sat on his hood at a carshow??
Old Jul 1, 2008 | 11:57 AM
edardnaekim's Avatar
ur bov is backwards
Old Jul 1, 2008 | 12:04 PM
mx4life85's Avatar
Really, I never touched it. Maybee the guy that had the car before me really didn't know what the hell he was doing.
Old Jul 1, 2008 | 12:12 PM
dsm25psi's Avatar
taylor i think the dealer has no idea what he is talking about. The sound was coming from the a/c pump area not the condensor and the bottom a/c line was all wet like it was leaking from there. The best thing to do is take it to a shop and let them test the a/c system they can locate the hole where its leaking from. I can tell you a good shop that did a lot of my work thy will find the problem.
Old Jul 1, 2008 | 03:32 PM
EatSleepBoost's Avatar
take out the a/c and use the money for mods. a/c for the loss
Old Jul 1, 2008 | 05:03 PM
mx4life85's Avatar
I would take out the AC, but I live in NC, and it gets hott. Plus this is my DD.
If it wasn't for the damn humity I wouldn't have a problem not running AC.
Old Jul 1, 2008 | 05:12 PM
ohh i c man. yea well if u must then get it check somewehre that is not a mitsu dealer and use aftermarket parts cause mitsu would be EXPENSIVE
Old Jul 1, 2008 | 05:14 PM
mx4life85's Avatar
Hopefully I'm going to get it checked tomorrow at DSM's friends shop.
Old Jul 1, 2008 | 05:27 PM
whitey4d's Avatar
Im not sure if mitsu put dye in the systems from the factory. I know all toyotas do and some nissans. If it were to have dye in it use a black light to look for anyleaks.
If seen several visibly damaged condensers not have a problem and blow solid mid 40* air out of them, I mean like give you goose bumps.
Have you checked to see if the compressor clutch is engaging?
Old Jul 1, 2008 | 09:25 PM
mx4life85's Avatar
All I know is that Mitsu. told me there is a leak in the system somewhere, and all the freon is coming out.
Old Jul 2, 2008 | 07:17 AM
andrewzaragoza's Avatar
get the aircon fix first. non need to replace the radiatore but you should keep a watch on it.
HKSevolutionNYC
Feb 2, 2016 10:27 AM
steven121
Feb 9, 2014 07:13 PM
AngryEvo8
26
Apr 20, 2011 09:11 PM
KevinD
11
Apr 21, 2008 12:45 PM
gvr4wd
May 26, 2006 07:35 AM
