Engine light
Old Jul 1, 2008 | 03:39 AM
Regenstein's Avatar
Engine light
I just had my new exhaust put on yesterday, which sounds amazing. But then last night my service engine soon light came on and has not gone off. I think it may be from the o2 sensor but not sure i haven't been able to get under the car to look to see if was hooked back up. Has anyone had this problem? Is it nothing to worry about or do i need to return to the shop?
Old Jul 1, 2008 | 05:20 AM
rahku's Avatar
are you running a test pipe?
Old Jul 1, 2008 | 05:42 AM
Kurt's Avatar
Just take it somewhere and have them plug into your OBD-II port instead of guessing what the problem is.
Old Jul 1, 2008 | 07:39 AM
BlueEvo61106's Avatar
If your running a test pipe you will throw a Check Engine code.
Old Jul 1, 2008 | 07:45 AM
jmelocik's Avatar
Go to the ECU flash section and look for the rear o2 eliminator patch. I did it to mine and no more SES light! However if you have to pass emissions I am not sure how it would effect it since I don't have emission where the car is registered. Let me know if you need any help.
Josh
Old Jul 1, 2008 | 08:12 AM
evo9mr0006's Avatar
So when putting on a new exhaust your gonna have to deal with the check engine light?
Old Jul 1, 2008 | 08:14 AM
evo8426's Avatar
no you get a mechanical o2 sensor fix and it doesnt come up
Old Jul 1, 2008 | 08:19 AM
btownsoccer22's Avatar
unless you get a high flow cat then no cel light
Old Jul 1, 2008 | 09:36 AM
bKevO's Avatar
+1 to that, I recently put in 1 drilled HELP anti-fouler (part#42009) worked like a charm....using both of them I would have left my o2 sensor somewhere on the highway
Old Jul 1, 2008 | 11:13 AM
S4STIEVO's Avatar
Just Get The No Foulers There 3 Bucks, And Ur Problems Gone
Old Jul 1, 2008 | 11:27 AM
TheoryVIII's Avatar
whats the difference in the test pipe and high flow cat is it less hp or worse sound??
Old Jul 1, 2008 | 11:35 AM
Regenstein's Avatar
Thanks guys for your help
