Do evo 8 have 2 step
Old Jul 2, 2008 | 05:29 AM
JakeTheVIII's Avatar
Originally Posted by vmrevo9
03's should have the 2step. i had flashed my friends evo 8 to adjust the new settings for it. it was set higher than the redline... (7906 stationary rev limit) redline was about ~7600. if i remember correctly the 2 step works a little different than my 9. in his 8 as long as the car was stationary with or without the clutch pressed it would go to the 2step once the car was moving it would rev up to the rev limit.
Originally Posted by alloutDSM
^^ huh?
I dont know how it works in the 9, but in my 8 it's they way he's talking about. If you are stopped, revving up regardless if the clutch is pressed, it should hit the 2 step. If you are rolling at all, it will rev freely past it.
Old Jul 2, 2008 | 07:43 AM
holler mcdollar's Avatar
Originally Posted by Toxin
A 2 step is an Evo feature that keeps companies like Exedy,ACT & Sheptrans in bussiness.
as much as this made me LOL it's totally true!
Old Jul 2, 2008 | 07:56 AM
LeosEvo's Avatar
Originally Posted by nightwalker
all U.S. EVOs have a "2 step". I have an 03 and I have mine set to 4800
you are kidding me right? not all U.S Evos have 2step 03-04's do not have it you may because you are tuned or flashed...
Old Jul 2, 2008 | 08:15 AM
LeosEvo's Avatar
2step for evo 8 or 9 is the same exact thing... and its weird that he could have a 2step without having the clutch pressed all the way in ''I NEVER HEARD OF THAT BEFORE''.... and if you have 2step while the car is moving you would never be able to get even close to redline lol....
Old Jul 2, 2008 | 08:24 AM
rahku's Avatar
ok us evos do have a two step but it is set past the redline
Old Jul 2, 2008 | 08:34 AM
Craig King's Avatar
Does anyone know if the Vishnu Exede tuning can be flashed to run a 2-step file?
Old Jul 2, 2008 | 08:43 AM
TalonTuner4G63's Avatar
"2 step" is weak anyhow. Anti-lag is where it's at. If your going to do drag racing BS and **** **** up, at least do it right.
Old Jul 2, 2008 | 08:44 AM
rahku's Avatar
a buddie of mine running a vishnu tune two step is set to 6300 i belive
Old Jul 2, 2008 | 08:54 AM
LeosEvo's Avatar
right... isnt that the REV LIMITER??? not a 2step right? correct me if im wrong
Old Jul 2, 2008 | 09:03 AM
UT_Evo's Avatar
Rev limiter: ~7600
Two step: ~7900
As was stated in previous posts.
PS, I effing hate the two step, as if the Evo really needs any help off the line... Now 16 year old kids can just floor it and drop the clutch all the time without even having to think of over-revving...
Old Jul 2, 2008 | 09:28 AM
Originally Posted by UT_Evo
...as if the Evo really needs any help off the line... Now 16 year old kids can just floor it and drop the clutch
And then immediatly jump on EvoM and ask if the "blah blah blah stage eleventeen 6 puck clutch" is the best to buy for their broke garb.
Old Jul 2, 2008 | 09:49 AM
JJsEvo8's Avatar
So i have an 05, i dont launch my car but I am curious. So my 2-step is over redline too? Where does the stock IX 2-step land then?
Old Jul 2, 2008 | 10:50 AM
def1's Avatar
how can be a 2 step be set past redline? Who launches there car at 7600 rpms?
I think you guys are thinking of the rev limiter not a 2 step.
Old Jul 2, 2008 | 11:53 AM
nk1124's Avatar
eh the "two step" they are talking about is a rev limiter. Theres the normal rev limiter which is like around 8k or something, and the stationary rev limit which is what most people are talking about when they say "two step" which is a rev limiter that is in effect when you are stationary, and is set lower in the 05+ models but set higher than the normal rev limiter in the 03 and 04 models.
Old Jul 2, 2008 | 11:56 AM
mcwop23's Avatar
factory two-steps from '05 on were set at ~5000rpms. Typically you see the best results on a mildly modded evo in the 5500-6500rpm range.
