HID leveling motor going crazy?
Old Oct 26, 2009 | 07:30 PM
revvin9k's Avatar
Originally Posted by WRCBred
My passenger side light does the same thing. I haven't had the problem with the drivers side *knock on wood*
When I tried to adjust the pass side it didn't want to move. I think my damn adjustment knob is broken inside the housing. I need to save up for JDM headlights.
Or just read the post above yours.
Old Dec 31, 2011 | 12:59 PM
drewbird91's Avatar
Okay I just did the blackout headlight how to on my hid headlights. I got everything back on the car and pulled it out on the driveway, put the key in the on position so I could turn the hid on and with the car off I hear the passenger side motor still running for about 30 seconds. It finally stopped. I turned the car off and then back on and it did the same thing for about 30 seconds, stopped for 10 or so than started buzzing again for another 10-15 seconds before it stop again. I didn't mess with the insider level adjuster. I also used the heat gun method to take the headlights apart. I'm not sure if it did this before. This is just the passenger side also. Any ideas?
Old Dec 31, 2011 | 03:22 PM
cmspaz's Avatar
Eh, my driver's side one hunts for a bit every once in a while. I read somewhere that it's normal? At least nobody's had issues resulting from it? I dunno. Not worried.
Old Jun 16, 2012 | 10:30 PM
ru4real's Avatar
I noticed this problem recently when I was waiting at a stoplight. Both sides are affected, and they move together. My HIDs are normally set to 0, but sometimes I switch to 1 if there's additional weight in the rear of the car, or if there is the potential of blinding oncoming drivers on hills.
I tested the level dial settings with the car facing my garage door. The problem is worst on setting 1. I can see and hear the motor changing the level up and down. The movement is much less and intermittent on 0, but it's still there. The issue disappears on the other settings.
This weird behavior definitely didn't exist when the car was new. This makes me think that the problem is directly caused by electrical contact wear in the adjustment switch.
Has anyone solved this problem by replacing the switch, instead of unplugging the motor and relying on manual adjustment only?
Old Jun 16, 2012 | 11:32 PM
Brigganator's Avatar
mine was going crazy to.. still havent figured it out.
twnty100drummer
14
Aug 30, 2017 04:56 PM
dhonda
Jan 9, 2016 09:51 AM
jpsEVO
Oct 26, 2013 12:49 PM
iEvoVII
Dec 26, 2011 03:33 AM
GraphiteEvo9
Jun 6, 2010 07:21 PM
