Escort Passport 8500 X50 problem.
Old Jul 27, 2008 | 07:09 PM
ohthree's Avatar
Everytime my car goes into boost the laser feature goes off, obviously, as you can assume, this scared the **** out of me the first 20 times it happened. But for some reason sometimes it goes off EVERY time I go into boost. Other times it turns on and nothing at all. Anyone have any similar problems?
Old Jul 27, 2008 | 07:29 PM
jpetro10's Avatar
is it hardwired in or just plugged in to the outlet?
Old Jul 27, 2008 | 07:35 PM
SRTRaceR04's Avatar
+1
Sounds like a short or something getting cross-connected or something. I too use the X50 but have never had a single problem with it.
I would try contacting Escort about it.
http://www.escortradar.com/contact.htm
Old Jul 27, 2008 | 07:40 PM
edogg23's Avatar
I have had one for like 3 years, suddenly about 6 months ago it started doing the same thing you decribed. I couldn't fix it so I ended up just turning laser protection off. Hope you find a solution.
Old Jul 27, 2008 | 07:42 PM
wizzo 8's Avatar
I have the same problem. I just beat it on the dash a couple times and its ok for a month or so. How do you turn off the lazer function?
Old Jul 27, 2008 | 07:45 PM
ohthree's Avatar
i just have it plugged in.
Old Jul 27, 2008 | 07:46 PM
bank277's Avatar
Mine started doing the same thing after about two years. I just turned off the laser alert. You can fix it if you want to here's the how to www.vistabug.com/bb/viewtopic.php?pid=70
Red Dragon's Avatar
typical problem with all x50. it has happend to me and everyone else that i know that has it. I just turned off the laser function.
Old Jul 27, 2008 | 07:52 PM
wizzo 8's Avatar
Good info. Thanks. But in the mean time how do you turn off the laser function?
Old Jul 27, 2008 | 07:56 PM
bank277's Avatar
Can't remember exactly how but it's in the manual/instructions.
Old Jul 27, 2008 | 07:58 PM
EvoBroMA's Avatar
typical issue if you have it resting on the dash. you can try mounting it higher, but the laser serves no purpose other then telling you you're going to get pulled over
Old Jul 27, 2008 | 07:59 PM
porsherules911's Avatar
Mine hasn't started doing it yet hopefully it stays like that.
bank277's Avatar
incase you've lost your manual www.escortradar.com/pdf/8500x50manual.pdf
Old Jul 27, 2008 | 08:06 PM
wizzo 8's Avatar
I did. Now that I read it I remember programming mine when I first got it. Thanks for the info
Old Jul 27, 2008 | 09:29 PM
Thoe99's Avatar
Mine does that every now and then. Once it starts, it does it almost every time during that day. I have it plugged into the cig lighter, mounted in the middle of my windshield (not on dash).
