Stock heat range HID for 06 evo mr
hey guys i need some help i was wondering if there was a way to adjust your headlights up and down besides the toggle switch in the cockpit because my passenger light is extremely brighter than the other. i mean bright it does not even have that blueish tint when i go over bumps at all like all the other evos i see with HIDS. do you guys think i need new bulbs or is that one out of wack is there anyway i can test them to be sure. if i need new ones what color and size and brand bulb do you think i should go with thanks guys i have been searching for this answere for a bit now it is really bugging me. thanks guys.
bump it is kinda embarrassing when someone you know is driving in front of you and asks when you see them what is wrong with your headlights lol on a 30k+ car please help me.
I dont have an answer for you, but for the IX, it should be (low beam) 9006 size. Color temp, can be what ever you want. As for the Watts, mine is running 35W, but I dont know if the MRs run the same.
not sure what you mean, but here is a link on how to adjust your headlights up & down.
https://www.evolutionm.net/forums/sh...ad.php?t=75583
since you have hid. stock heat range is 4300k. try the headlight adjustment first. maybe its aiming to high/low. level it. Try to look at the bulbs, if your not the first owner maybe two kinds of bulbs are in there.
The reasoning why one may look bluer is because you're looking into the cutoff of the projector. There is normally alot of blue/purple colors along the cutoff due to the optics of how a projector works.
The other projector is pointed to high, so it's not going to seem as blue.
Take a picture of your headlights against a white wall. I'd like to see how far off they are. That'd help alot!
the right one is supposed to be aimed higher to see street signs, while the left one is lower as to not blind on-coming traffic.
i got really annoyed when my body guy aligned them both level! They are not supposed to be level :/ its just that everyone adjusts them level.
Code:
________ ______/
