How to fix rattle
Old Aug 5, 2008 | 02:25 PM
fmly evo's Avatar
How to fix rattle
The Shield around my (aftermarket high flow) cat is rattling. can i take it off or should i have someone re-weld it? i don't think it is anything but cosmetic but it is annoying as hell
STevo
Old Aug 5, 2008 | 03:13 PM
slvrr's Avatar
Its just a heat shield I don't see the problem with taking it off. I have yet to see a test pipe with a heat shield you will be fine..
Old Aug 5, 2008 | 03:25 PM
TURNinCONCEPTS's Avatar
Oh man! That buzzing you get with those is annoying. My vote is to just ditch the shield.
Old Aug 5, 2008 | 04:15 PM
highbredcloud's Avatar
I have a similar rattle but I have stock exhaust...does a stock exchaust come with a heat shield as well? I get the rattle above 70MPH and mostly when the A/C is on...weird...
Old Aug 5, 2008 | 04:32 PM
srajeremy's Avatar
it might be the heat sheild above the exhaust or the downpipe heatshield is loose i would take a look at the dp and maybe if there are scuff marks on the heat shield otherwise it might something more serious. has anyone taken that heat shield off by the way? the one above the exhaust that goes all the way down it rubs against my bigger exhaust and is really annoying. i want to but im not sure if it will burn something
Old Aug 5, 2008 | 04:39 PM
srajeremy's Avatar
it might be the heat sheild above the exhaust or the downpipe heatshield is loose i would take a look at the dp and maybe if there are scuff marks on any of the heat shields otherwise it might something more serious. has anyone taken that heat shield off by the way the one that goes all the way down above the exhaust. it rubbs against my bigger exhaust and is really annoying? i want to but im not sure if it will burn something
Old Aug 5, 2008 | 04:46 PM
fmly evo's Avatar
great i will be taking it off this weekend then. thanks for the responses.
STevo
Old Aug 5, 2008 | 04:51 PM
tofuprince's Avatar
There are just too many rattles to be fixed
Old Aug 6, 2008 | 10:56 AM
GTWORX.com's Avatar
I fixed the exhaust heat shield on my old subaru with stainless steel hose clamps. All better, and the heat shield is still in place doing its thing quietly. Takes some time to find the exact spot of the rattle but you'll find it.
- Andrew
Old Aug 6, 2008 | 11:08 AM
BadNewsEvo's Avatar
ya I just took mine off... weight reduction lol
jbuhrman
28
May 2, 2016 12:08 PM
boobcakes
Evo X How Tos / Installations
55
Dec 19, 2011 10:05 PM
WADADLIG_OZ
14
Feb 20, 2004 03:57 AM
Souren
Lancer Troubleshooting
Aug 19, 2003 12:49 PM
agsmooth84
16
Apr 29, 2003 09:03 PM
