91 and 100 Octane Mix
Old Aug 23, 2008 | 12:28 AM
vegasevo9's Avatar
IS it worth it to fill up 50% 91 octane and 50% 100octane? I am currently tuned at 91..
Old Aug 23, 2008 | 07:28 AM
Vibrant's Avatar
No.
Old Aug 23, 2008 | 09:13 AM
Warrtalon's Avatar
Yes, if you run more boost. Yes X 2 if you run more boost AND get a second map for 95.5oct (50/50 mix of 100 and 91). If you do nothing but just add some 100 to your current setup, then the only power you could gain is power being LOST due to knock on the current tune (if there is any).
Old Aug 23, 2008 | 10:17 AM
Vibrant's Avatar
[QUOTE=Warrtalon;6040378]Yes, if you run more boost. Yes X 2 if you run more boost AND get a second map for 95.5oct (50/50 mix of 100 and 91). If you do nothing but just add some 100 to your current setup, then the only power you could gain is power being LOST due to knock on the current tune (if there is any).[/QUOTE]
Case in point?
Old Aug 23, 2008 | 06:46 PM
vegasevo9's Avatar
I will probably just get retuned to a higher boost with 100 octane. Thanks for all the info.
Creatre
Nov 6, 2015 04:43 PM
salukidude
West Region
15
Mar 11, 2005 04:19 AM
reTro
Oct 13, 2004 08:59 AM
Miss Evo 8
Jun 15, 2004 05:12 PM
TwoMix9900
Feb 25, 2004 11:35 AM
