attendant GAVE ME 3 GALLONS OF REGULAR
Old Sep 1, 2008 | 04:01 AM
DRAGHICI's Avatar
I told him to fill it up, he started using regular.
ended up getting 3 .11 gallons of 87, filled up the rest with 93.
should i be worried?
I'm gonna buy a 107 octane booster, in the mean time.
Old Sep 1, 2008 | 04:31 AM
DRFTKNGG's Avatar
your fine...use the Lucus Octane booster.
Old Sep 1, 2008 | 05:15 AM
1NASTYIXMR's Avatar
You should be fine without the octane booster, just stay out of boost untill you fill up next.
Old Sep 1, 2008 | 06:26 AM
JakeTheVIII's Avatar
That would make me so mad. But I guess he was trying to do the right thing and save you a little money, probably thought it was just a lancer.
Old Sep 1, 2008 | 06:34 AM
TTP Engineering's Avatar
Thats what happens when you take the spoiler off.
Old Sep 1, 2008 | 06:58 AM
06ravenmr's Avatar
u have nothing to be worried about. use to do it all the time to save money
Old Sep 1, 2008 | 07:17 AM
EvolNinja's Avatar
They need to look at the gas cap before filling her up
Old Sep 1, 2008 | 07:27 AM
EvoJoeIX's Avatar
are you serious?
Old Sep 1, 2008 | 07:34 AM
[Advance]'s Avatar
Originally Posted by EvoJoeIX
are you serious?
haha I know. What are you thinking?
Old Sep 1, 2008 | 07:38 AM
Kracka's Avatar
No worries, if the ECU sees knock it will just pull some timing, but my guess is the car will run perfectly with only 3 gallons of regular in there being diluted by 93 (remember, these cars were designed to run on 91).
Old Sep 1, 2008 | 07:44 AM
meltdown's Avatar
They were designed to run on 93. Check your manual.
Old Sep 1, 2008 | 07:50 AM
Kracka's Avatar
Mine clearly says 91 is acceptable. Minnesota doesn't even have 93.
Old Sep 1, 2008 | 08:47 AM
EvoJoeIX's Avatar
they can run on 91... look how many are in CA
but not 87..... you just cant run that crappy fuel in your car. if you cant afford premium, then maybe you cant afford an evo (not directed to the OP)
Old Sep 1, 2008 | 08:58 AM
Masta Z's Avatar
filling it up yourself ftw
Old Sep 1, 2008 | 09:03 AM
kellieanne's Avatar
well... its kind of your fault for not pumping your own gas.
