help!!! defi bf boost gauge wont turn on.
Old Sep 21, 2008 | 01:41 PM
jlee's Avatar
ok so yesterday i installed my defi bf boost gauge with the controller. i bought the gauge and controller from a evom member.
i followed the directions very carefully and did everything according to the "how to" http://www.evolution-8.com/howto/defi.php
now here is my problem, the gauge itself wont turn on but the controller works just fine as far as i can tell. the controller lights up.
please help me. im very frustrated with this whole thing. thanks in advance.
Old Sep 21, 2008 | 01:42 PM
Duh Panda's Avatar
did you wire up the gauge power source properly?
Old Sep 21, 2008 | 01:49 PM
jlee's Avatar
what gauge power source? there is only one meter wire from the controller to the gauge.
Old Sep 21, 2008 | 01:57 PM
mump's Avatar
make sure you plug that gauge wire into source 2 on the back of the controller
Old Sep 21, 2008 | 02:01 PM
jlee's Avatar
it is on source 2. your talking about the "meter output 2" rite?
thanks for all the replies.
help please.
Old Sep 21, 2008 | 02:14 PM
mump's Avatar
help please.
yeah, that is what i meant. you said the controller lights up when you turn the headlights lights on/and turns off, right? only thing light is to make sure the wires are good btwn the boost unit box to controller and from controller to gauge. i once pulled a wire out of one of those little connectors. it was a real PITA. good luck.
Old Sep 21, 2008 | 02:25 PM
jlee's Avatar
yeah the controller lights up when i turn on the headlights. i made sure that i connect everything correctly. sensor to controller to gauge. and as for the controller's power source, i used the radio harness with these colors.
Red with Red w/ Black Stipe Constant Volt.
Orange with Blue w/ Yellow Stripe Ignition On
White with Green w/ White Strip Illumination
Black with Bolt near radio Ground
is it possible that the gauge i bought is fried?
Old Sep 21, 2008 | 02:28 PM
Duh Panda's Avatar
possibly... someone sold me a fried controller box... but the gauge works
ill sell it to you
whatever you offer its yours
Old Sep 21, 2008 | 02:33 PM
Knguyen228's Avatar
does the gauge function beside not lighting up? maybe the bulbs burnt?
check your wire and connectors that connects to the controller and the gauge for any cuts that may be cause from uninstalling.
Old Sep 21, 2008 | 02:35 PM
jlee's Avatar
ill sell it to you
alright thanks but i got to double check. i will take it to a shop and see whats going on. if my gauge is fried, i will buy it off of you.
Old Sep 21, 2008 | 02:38 PM
Duh Panda's Avatar
lol yea take it to a shop maybe you missed something .... check your fuses and what not...
wish i could help more but i totally forgot how i wired mine up
Old Sep 21, 2008 | 02:40 PM
jlee's Avatar
no the gauge does not function at all. i checked all the wire connections and all seems fine to me.
Old Sep 21, 2008 | 02:51 PM
jlee's Avatar
its all good. thanks for the help.
Old Sep 21, 2008 | 07:37 PM
jlee's Avatar
help!
Old Sep 22, 2008 | 08:50 AM
BBS's Avatar
BBS
Just think objectively. If the controller works then the only culprits are the wire from unit to gauge or the gauge itself.
ch1215g
11
Dec 20, 2010 01:57 PM
turbo4g63
41
Jun 30, 2009 04:45 AM
SPOOLED IX MR
Aug 21, 2006 06:11 AM
essjEVO
Dec 25, 2005 10:06 AM
chills
Jun 14, 2005 11:15 PM
