stock ecu map
Old Sep 23, 2008 | 07:07 PM
manofhonor's Avatar
here's the video of the exhaust idle
http://www.youtube.com/watch?v=ANRPDbCJsDI
Old Sep 23, 2008 | 07:17 PM
def1's Avatar
thats definitely not cammed.
here is a cammed evo
http://www.youtube.com/watch?v=-Hl5PZlEhi4
Old Sep 23, 2008 | 11:39 PM
manofhonor's Avatar
well damn i seriously wouldve taken you up on that trade too haha. so then its safe to go for a stock map then i suppose? im eventualy gonna get a turbo back and tune to accompany, im jsut trying to get a feel for the stock evo right now as this is my first. i upgraded from the wrx so im probably just over reacting when i hear some noises or vibrations huh?
Old Sep 24, 2008 | 09:45 AM
Redline-Z's Avatar
Veteran: Air Force
For one it sounds like you have a Walbro 255 in it which leads me to believe the ROM isn't stock. What is your launch control set at? Also, not all cams give the note posted above. It almost sounds like it might have a slight lope, if cams are causing that??? Pull your plugs and take a look along with finding a tactrix cable and looking at your ROM.
Also you wouldn't hear the lope as bad with a stock exhaust.
Old Sep 24, 2008 | 02:41 PM
manofhonor's Avatar
yeah ive been searching around and my rev limiter is set at like 6k rpm, 500 above what it should be. so next question is if i take the valve cover off how can i tell of the cams arent stock by just looking at it?
Old Sep 24, 2008 | 03:13 PM
EvoJoeIX's Avatar
look for any ingravings in them... like a company name or part number.
have u checked your cam gears yet?
Old Sep 24, 2008 | 05:42 PM
manofhonor's Avatar
well guys i dont think i have stock cam gears haha. proof:
http://i538.photobucket.com/albums/f...4/IMG_1776.jpg
im starting to think its a pretty good chance that i dont have stock cams, so im gonna take the valve cover off tomorrow and take pics of my cams and post it and see what you guys think.
Old Sep 24, 2008 | 05:55 PM
evo8426's Avatar
your rev limiter is supposed to be set at 5000 not 5500
Old Sep 24, 2008 | 06:07 PM
manofhonor's Avatar
well whatever it is its at 6k rpm right now. im starting to think this is not as stock as i thought it was. ive got aftermarket cam gears, possibly cams, and now im pretty sure my ecu map isnt stock cause my rev limiter is at 6k
Old Sep 24, 2008 | 06:21 PM
cssaddictm4's Avatar
It may be the angle but it looks like your cams are set on a +/- degree offset. It doesn't look like they are respectively at 0.
Old Sep 24, 2008 | 06:32 PM
manofhonor's Avatar
so what does that mean if theyre not set to 0?
Old Sep 24, 2008 | 06:41 PM
It could mean many things. One of which that your car may have had a bigger turbo on it at one time, or may still have one. Second is that you most definity have aftermarket cams. Adjusting your cam gear timing can change your power vs rpm range. You can adjust the timing to help spool a turbo and make power in the low end or make it so that you gain a lot of up top power. IMO I would have an experience EVO tech go over your hole car to make sure everthing is a 100% so nothing breaks. If you car was "put back to stock" the owner could have been careless.
Old Sep 24, 2008 | 07:47 PM
manofhonor's Avatar
ok so when i take it to a shop that specializes in evos, what parts should i have them look at to see if theyre stock or not?
Old Sep 25, 2008 | 01:26 AM
Redline-Z's Avatar
Veteran: Air Force
Word of advice, start a thread with pics here asking who owned the car and maybe you'll turn up someone who can awnser your questions. The car was modded so the person was likely a member of the forum.
Old Sep 25, 2008 | 11:11 AM
Rob_GPT's Avatar
Could be tons of stuff now. Take a picture of the turbo for us.
How car savvy are you? Would you know an aftermarket downpipe or intercooler if you saw one?
