Help ANyone Had these Codes before
Old Oct 28, 2008, 11:55 PM
RABYRAB's Avatar
Heres what I am getting: P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low - I replaced the throttle body sensor (with a used 1 but haven't driven the car yet)
P0113 Intake Air Temperature Sensor 1 Circuit High -- Maybe this is the 1 about my air leak
P0117 Engine Coolant Temperature Circuit Low
I have no idea about this one, anyone please help????
Car was running fine until I swapped for a 9 turbo on my 8. Now the car just shuts right down. and ets piping and hks intake and pipe. There is a massive air leak I found on the turbo side of the exhaust manifold which i am fixing. What do all these codes mean? Is it time for a stand alone ecu? If I replace a sensor will it f up again and is that the solution?
Thanks in advance
Old Oct 29, 2008, 08:00 PM
RABYRAB's Avatar
Help
Old Oct 29, 2008, 08:07 PM
EatSleepBoost's Avatar
yo do not need a standalone.
fix ur air leak. as far as coolant temp, its common for those sensor to go bad or you may have air in ur cooling system. run the car with the coolant cap off to let the air bubbles out, top the fluid off then put the cap on.
Old Oct 29, 2008, 09:37 PM
RABYRAB's Avatar
what do I need?
Old Oct 29, 2008, 09:39 PM
RABYRAB's Avatar
the car doesnt run it dies.
sikrsix's Avatar
^^ you need to fix whats wrong with your car first.
Old Oct 29, 2008, 09:53 PM
RABYRAB's Avatar
Thats the problem i dont know if its a fuse or after i fix the air leak in the mani and radiater if it is something else
christianreed91
Sep 11, 2016 09:12 PM
SpeedLimit55
28
Dec 23, 2015 02:27 PM
miller121mx
Mar 31, 2011 06:41 PM
WADADLIG_OZ
Lancer Troubleshooting
10
Jun 23, 2009 09:25 AM
BadazzCR
Aug 23, 2008 07:40 AM
Quick Reply: Help ANyone Had these Codes before
