Installing gauges
Old Dec 15, 2008 | 07:22 PM
cssaddictm4's Avatar
Originally Posted by 19DB794
Thats the only way I install my electronics. I dont use any t taps or any type of crimp connections. I prefer to install and wire electronics once and do it right once.
Good to hear. I have seen so many people use way to much unnecessary wire as well as crimp style connections.
OT:
A person came to me asking for help on why is stereo fuse was shorting (gauges were connected to the circuit). I removed eight feet extra of wire that had "T's" every which way. Soldered and head shrunk the wiring and the problem disappeared
Old Dec 15, 2008 | 10:19 PM
Broxma's Avatar
My factory triple gauge panel was wired to a harness off the factory radio. If the factory installs it that way I assume it can be considered correct.
In addition, Prosport gauges use a daisy chain loop system on some of their gauges where each gauge has an input power and output. I have seen as many as 6 gauges ina row wired using this method with no problem. I really don't think the voltage draw from the gauge is that high so wiring one gauge to the next on a small scale is definitely ok.
/brox
Old Dec 16, 2008 | 11:22 AM
Joshs EVO's Avatar
I also hooked my gauges into my stero, They do have the ports for other things well at least on the deck I have. Wired it in and they shut off when the stereo shuts off.
Old Dec 16, 2008 | 01:39 PM
19DB794's Avatar
Thanks for all the help. I should get my boost gauge tomorrow or thursday. If I have some daylight left I might install it once it gets here.
turbotaloon95
May 16, 2017 01:57 PM
W06EMR
Feb 26, 2011 11:07 AM
belizelittle39439
Mar 11, 2007 06:37 PM
qbbraveheart
Mar 18, 2005 08:48 AM
ericomundo
Aug 18, 2003 08:06 PM
