harness bar?
Old Dec 18, 2008 | 07:08 AM
gdup's Avatar
harness bar?
anyone have a harness bar and does it do anything for the handling. It says reinforce chassis.
is this just a camera mount/ waste of time and money or is it worth it? thanks
Old Dec 18, 2008 | 07:17 AM
CaliMR's Avatar
It is primarily for mounting a harness. Any handling benefits would probably be negligible. Do NOT put people in the back seat if you have a harness bar. I would not put one in without a cage or at least a serious roll bar, because if you flip and the roof collapses then the bar will crush you against the roof. And with a cage, you should not drive without a helmet or you are asking for some serious head trauma if you get in an accident.
Basically, don't do it unless you are ready to turn your car into a track only car.
Old Dec 18, 2008 | 07:21 AM
gdup's Avatar
thanks u just talk me out it. i never knew the crushing part. thanks a lot
Old Dec 18, 2008 | 09:15 AM
def1's Avatar
cant u buy foam for it
Old Dec 18, 2008 | 09:35 AM
Arkitek's Avatar
a lot of people buy it for the harness and looks....
Old Dec 18, 2008 | 09:38 AM
lexat20's Avatar
I used mine primarily for a camera mount. I did use it for harnesses too. Your best bet if you want harnesses is to look for a roll bar, Autopower makes a bolt in. This will give you more safety in a rollover, a camera mount, and a harness bar. Difference in price is less than a couple hundo, well worth it if you ask me.
Old Dec 18, 2008 | 10:20 AM
Jeff_Jeske's Avatar
If you want to stay planted without the hassle or risk of a harness and bar..... get a CG-LOCK. They are fairly cheap and work very well. Takes 5 minutes to install and remove.
Old Dec 18, 2008 | 10:22 AM
gdup's Avatar
looks good
i want the one in ur pic.
Old Dec 18, 2008 | 10:28 AM
CaliMR's Avatar
+1 I have one and it works well, but I would remove it when you are not at the track so you do not wear out the belt retractor.
You can foam the cage/bar but I still would not drive it without a helmet. I have seen helmets destroyed from hitting a foamed bar, and helmets are stronger then skulls.
There is a ghetto mount you can make for a camera by removing the center child seat anchor one the cargo shelf behind the rear seats, and you replace it with a longer bolt through the center of the head of a cheapo tripod that you tore in half. There is a thread about how to do it here, I used it for a while and it worked ok but it is not great because the camera is too far back.
Or you can go GoPro and use a suction cup, but some track day organizers do not allow suction cups.
Old Dec 18, 2008 | 07:10 PM
Trail Slide's Avatar
^pic of helmet?
Old Dec 19, 2008 | 07:06 AM
NVmySKILS's Avatar
From: across the river from the city that never sleeps
y would you want to keep her planted..
