Question about fixing stainless pipe
Old Dec 27, 2008 | 01:31 PM
lv05evo's Avatar
Question Question about fixing stainless pipe
Hello all,
I was wondering if the some of you guys may know how to fix a dent from stainless steel exhaust pipe. I have a feeling that performance won't be hurt, but if it is easy enough then I'll fix it. Take a look at the pics to see what I'm talking about. Thanks
Old Dec 27, 2008 | 01:36 PM
MR_Evo_Rob's Avatar
I wouldn't even worry about that.
what kind of exhaust is that?
Old Dec 27, 2008 | 01:58 PM
lv05evo's Avatar
Cobb 3 in.
Old Dec 27, 2008 | 03:22 PM
MR_Evo_Rob's Avatar
Gotcha. Fixing SS is a huge pain b/c of how strong it is. I'd leave it be. Are you trying to sell it or did you get it that way?
Old Dec 27, 2008 | 03:29 PM
Psquared's Avatar
I'd leave it. Chances are you'd crack it trying to bend it back.
Old Dec 27, 2008 | 06:13 PM
VRSF Tiago's Avatar
In order to fix that you'd probably have to cut the pipe, heat it up and use a pipe expander to get it back to round.
Old Dec 28, 2008 | 02:15 PM
lv05evo's Avatar
was thinking of buying it to save some cash.
Old Dec 28, 2008 | 02:42 PM
Abizzle's Avatar
Try to push it out with a pry bar, or you can try to heat it up and put something in it thats kind of got the same shape... I dont think it would mess the performance of the exaust though...
Old Dec 28, 2008 | 02:51 PM
jroller's Avatar
What you can do is try a pipe expander (sold at most parts stores), it may work it may not. What I would do though is tig weld a series of small rods along the line of the dent and use a dent puller to gradually raise the area. Then cutoff wheel the small vertical rods, sand flush, and polish. If this seems like a lot of work it is. In all actualilty you wont notice a performance difference just leaving the dent the way it is.
Old Dec 29, 2008 | 10:10 PM
Q@EvoPowerMods's Avatar
Carefully heat up the area then insert a baseball bat(of course that you wont mind getting slightly burnt) then gently tap the area affected. I've done this several times and it works wonders. The dent does not appear deep enough to effect performance however; we are all about worrying about this kinda stuff, so just repeat my procedure and it will work itself out. Only worry is getting the area too hot, which is not that much of a worry. Get a MAP torch at your local hardware(HDepot,Low-s,etc) heat the area until cherry(colour) hot then apply the bat gently tapping..there you go..
Old Dec 29, 2008 | 11:27 PM
lv05evo's Avatar
Thanks, I was think of using a metal pipe I have from my cloths hanger(I hang dry my shirts I don't want shrinking), but a wooden bat is better.
Extreme Dimensions
Apr 9, 2018 01:01 AM
Faisalm
For Sale - Cars For Sale
22
May 23, 2014 05:56 PM
06redrocket
33
Dec 31, 2013 07:39 AM
Evo Tengoku
For Sale - Wheels / Tires
Jun 18, 2008 11:37 AM
TheBatmobile
May 18, 2008 05:35 PM
