Stock Front/JDM Rear Bumper sagging? Any one else have this issue?
There is a thread on evom called "the official part number thread" or something like that. Search on there and you will find posts by me talking with another member and this member gives me all of the part numbers for the hardware under the headlight. Again, I feel you only need the black plastic square clips. I ordered everything and didnt need anything but those. I ordered them from the dealer. Took about two days and $3. Now it looks good as new! A pic as proof!
I probably had my front bumper on and off 10 times and it alwasy went back in fine. Then I put on the lip which made the whole thing more rigid and harder to line up. So I cranked a little too hard on the scews hoping it would pull things together and instead stripped out my black plastic clips and I had about 1/4" of gap on each side. Now as you can see it looks sweet.
I tried this today and I think the reason why its not working any better than the bolt, is because the plastic square is sagging itself because of wear .. I'm going to replace those and then try to use the original bolts.. if that fails, then I'll try the zip tie again. thanks
MRmike
17
Sep 2, 2016 06:05 AM
