My Darn recirculating button...
Old Mar 7, 2009 | 08:44 AM
Aar0nsite's Avatar
I have a problem with my recirculating button. the button's light is always on as if i turned it on but when i press it, i doesn't turn off. no matter how many times i press it, it still stays on. Its not a big problem, but i would like to fix it
thank u.
Aaron
Old Mar 7, 2009 | 11:27 AM
Maximum404's Avatar
Veteran: Navy
Have you pulled the panel and checked the physical connection?
Old Mar 7, 2009 | 12:58 PM
binarysleep's Avatar
Just in case. . .
Is your temperature dial set to MAX A/C?
Old Mar 7, 2009 | 01:11 PM
heel2toe's Avatar
^If I remember correctly if its on max you will not be able to turn of the recirculating feature. Try lowering the speed then turning the recirculating button off then turning the speed back up. There was some type of trick along these lines so just play around with it and you will figure it out.
Old Mar 7, 2009 | 01:43 PM
dsm2308's Avatar
^ this is correct, the recirculation light will always be on when it is on the max ac function
Old Mar 7, 2009 | 02:12 PM
DocCola's Avatar
funny story, I had this same "problem" for the first 2 or 3 weeks I drove my car. I felt like the biggest idiot when I figured it out.
Old Mar 7, 2009 | 06:55 PM
Aar0nsite's Avatar
actually my AC is off and the light is still on and there is no turning it off... but imma tr putting max and then pressing the button to see if it works. thanks guys!
Old Mar 7, 2009 | 06:59 PM
o7'silvermax's Avatar
at least your lights work!!! mine dont!
Old Mar 7, 2009 | 11:47 PM
koey03's Avatar
check the connections?
Old Mar 8, 2009 | 09:51 AM
Epix_'s Avatar
Just turn the ac knob one click off of max ac. That's the whole function of max ac. It has to recirculate in order to reach its maximum efficiency.
