Where is the tach wire?
Old Sep 22, 2003 | 08:41 PM
turbonawd's Avatar
Does anyone know where the tach wire is located on the Evo besides on the ECU..
I'm trying to install a Remote Start Alarm.
Old Sep 22, 2003 | 09:00 PM
mrdecibel's Avatar
Why are you avoiding the ECU. If you avoid ECU, you will have to grab it under the hood.
Old Sep 22, 2003 | 09:34 PM
turbonawd's Avatar
do you know where it is under the hood?
I might have to just use the ECU if I can't find it..
Old Sep 22, 2003 | 10:02 PM
Deceit's Avatar
get the field harness so you wont have to tap into your "real" ecu
Old Sep 23, 2003 | 03:49 PM
Coolguy949's Avatar
You need to tap pin 89 on the ECU known as the "Crankshaft Position Sensor". This is where your tach signal can be obtained for devices like turbo timers, fuel controllers, etc.
Old Sep 25, 2003 | 08:05 AM
SpeedFactor's Avatar
The Tach Wire is located as a Black/Green wire located under the valve cover. You can find it running into the Direct Ignition. Sounds like you are installing remote start on your alarm ?
Old Sep 25, 2003 | 08:19 AM
zupber4930's Avatar
You can also find it at the cluster (i.e. Tach wire for the Tachometer) broblem is I forgot the color of it. I want to say white, but might be green with silver dots.
Old Sep 25, 2003 | 05:55 PM
Coolguy949's Avatar
On my eclipse behind the cluster it was green with silver dashes when I installed a monster tach a couple years ago.
D420mac
Evo X How Tos / Installations
Jan 28, 2011 04:09 PM
TunerTools
Sep 5, 2008 07:35 AM
bigric09
Jun 18, 2007 02:00 PM
DCD
19
Feb 22, 2006 11:30 AM
yellance
Lancer Engine Tech
Jul 15, 2004 08:08 PM
