EVO IX gauge lights
Old Apr 24, 2009 | 07:29 AM
jakkaru_kitsune's Avatar
EVO IX gauge lights
So I swapped out my stock Lancer gauges for that of an EVO IX. Everything is working fine except that the gauge lights are on even when the park lights and head lights are off. I was just wondering if this was normal or if there is a way to fix it? Thanks.
Old Apr 24, 2009 | 07:35 AM
evokid511's Avatar
did you tap power for the gauges into the light switch power?
Old Apr 24, 2009 | 07:46 AM
BBoostin's Avatar
Evo gauge clusters stay illuminated with the headlights off.. completely normal
Old Apr 24, 2009 | 10:55 AM
AIEvo9MR's Avatar
Like evokid511 said. You tapped the wrong place. They ONLY turn on when your parking and/or headlights are on.
Old Apr 24, 2009 | 12:30 PM
evokid511's Avatar
if you want the gauge lights to shut off when you turn yuour lights off then you need to tap power from your light switch not from the factory gauge power( if the factory gauges do stay on like BBOOSTIN said)
Old Apr 24, 2009 | 04:02 PM
I used the stock wiring harnesses that my lancer es already had. I didn't cut any wires. The two wire harnesses just plugged in. Would I need to rewire? or is it normal like BBoostin said? Thanks for the response everyone.
Old Apr 24, 2009 | 07:41 PM
TcJayLee's Avatar
^Nice.
Old Apr 24, 2009 | 11:03 PM
SICK9's Avatar
Guage lights are always on, even when the lights are off.
It's not full bright, but they are on none the less..
100% normal..
Old Apr 25, 2009 | 04:07 AM
Thank you all very much! I can stop freaking out about hooking something up wrong now.
cts4g63
Nov 23, 2015 05:09 PM
texasevo
Aug 27, 2015 09:14 PM
binhtran
Dec 9, 2007 07:25 PM
avo3vom
Aug 12, 2007 08:56 PM
ApexVIII
11
Apr 24, 2007 12:13 PM
