View Poll Results: Ratio from Evo's who have problems to the ones with no problems
no problems here
364
75.36%
minor clutch problem
38
7.87%
transmission problem
32
6.63%
other
49
10.14%
Voters: 483. You may not vote on this poll
No problems with evo.
Old Oct 30, 2004 | 12:39 PM
  #121
90GSX-03EVO's Avatar
Originally Posted by glgz
I was just wondering what you mean by Fast is slow and slow is fast. Because at higher rpms I get a little bit of grind going into fifth maybe I am doing something wrong?
Your problem is actually a synchro assembly. There is a TSB on it and you can get it replaced under recall.
What I was meaning about "fast is slow and slow is fast" applies to all shifts in this car, though. When you change gears, you can't do it like in a Mustang - slamming it bac forth as fast as you can. These transmissions are connected with cable linkage. You have to take your time and "finess" the shift.
All you 1-2 shift grind guys can complain all you want about how the car is of inferior build and you should be able to shift as fast as humanly possible and all....That isn't the case. You need to learn how to drive the car properly. I'm not trying to be cocky, but in the end, you're the one grinding and I'm the one who isn't, and we both drive the same car.
Old Oct 30, 2004 | 06:29 PM
  #122
glgz's Avatar
Thanks, for the reply. I had heard it could be took care on warrenty . I wasn't aware of the TSB on it. Other than the 5th gear high RPM problem I have no other tranmission or clutch problems at all.
Old Nov 16, 2004 | 08:39 PM
  #123
two2thehead's Avatar
[B] 21,000 and the clutch went out. Dealer said it's the farthest the've seen go. I really don't won't to have to replace the clutch every couple of years.
Old Nov 16, 2004 | 09:00 PM
  #124
plokivos's Avatar
dealer told me 50,000 was furthest.
I changed mine at 30,000... but I think I could of gone another 10,000 with it.
Old Nov 16, 2004 | 09:15 PM
  #125
autoXer14's Avatar
purchased the car march 2004. just turned 13000 today. no problems . took this car to half day of autocross school when it had only 1000 which included braking, skidpad, some excercises requiring you to launch the car. been autocrossing the car once a month. no problems at all. still believe it is a great car even after mitsubishi motors flagged or should I say voided my warranty after they found out I am autocrossing the car.
Old Nov 17, 2004 | 04:48 PM
  #126
plokivos's Avatar
really just depends on the dealership. But I wouldn't tell them you do anything with the car except drive it slow. lol.
I tell them it was the other red evo that was racing or auto xing.
Old Nov 17, 2004 | 05:23 PM
  #127
cotmfk's Avatar
21k miles and no problems.
Old Nov 17, 2004 | 05:33 PM
  #128
WrX Kila's Avatar
Lets see, belt and tensioner replaced. Rotors resurfaced then replaced. All under waranty. No problem with The Mighty MMC.
Old Nov 17, 2004 | 05:48 PM
  #129
plokivos's Avatar
how did you get your rotors resurfaced? at what mile?
I had to pay $220 for that service at 25000 miles.
Old Nov 17, 2004 | 09:39 PM
  #130
bdking57's Avatar
almost 45K and no problems. I really think the clutch problems are a result of not being able to resist the urge to smoke the driver next to you reving their engine off the line.. if you can avoid doing this and hard launches the clutch will be fine. My clutch is still very tight.. feels like new.
Old Nov 18, 2004 | 04:57 PM
  #131
eclipsegs2k1's Avatar
10,000 miles. Zero problems
Old Dec 30, 2004 | 10:29 PM
  #132
striderx88's Avatar
on first gear when u let go the clutch too early and the car is about to stall would tat cost a problem because im still not use to the car yet everytime i drive its like that so would this cost any problems?
Old Dec 31, 2004 | 01:08 AM
  #133
RaceBiscuit's Avatar
23,000 miles on the and the rotors are warped. I love this car so much it really doesn't phase me, at least my stock clutch is still alive & kickin'. Guess I'll see what my local dealer's like with warranties...I'm assuming that should be covered since I didn't do anything to cause the problem...
Old Dec 31, 2004 | 01:11 AM
  #134
aw crap didn't read the above thread (plokivos) so rotors are considered a "wear" item or what?? They really shouldn't be warping at this mileage. My civic lasted 150,000 miles on the same damn rotors. (I know, apples and oranges, but still). Crapola.
Old Dec 31, 2004 | 01:14 AM
  #135
plokivos's Avatar
you could always try it. I did got it done because I had to resurface my rotors due to extremely worned down pads. yeh, I had to wait for my pads to arrive for a while.
