Oil pressure sensor wiring harness clip
Old Jun 6, 2009 | 12:51 AM
Johnboy1065's Avatar
Hey ya'll
Made a small mistake today,
I was pulling on something and didnt realize that the little wire running from the harness into the oil sensor had stress on it.
well, I seperated the wire that is supposed to go inside the clip from the clip.
I ended up soldering them back together But I was just wondering if anybody knows where I could get the clip for this?
also, this isnt really important since I have a defi gauge right? even if the car thinks it doesnt have oil that would just make the oil light come on right? It wouldnt affect the ECU (or EMS in my case) I do have the connection soldered I'm just talking worse case scenerio if it were to come undone somehow....
Old Jun 6, 2009 | 01:01 AM
BTW the cip thing that the wire came out of was black. and it mates with a tab on the Oil pressure switch that has a hole in the center of it that the cip interlocks with
its the same thing that's on the starter signal wire and the coolant temp signal wire
it's actually this sucker that I circled in the pic
Old Jun 6, 2009 | 07:20 AM
JakeTheVIII's Avatar
Probably only from mitsubishi. You should be fine though, if the light comes on, you know the soldering didn't fix it.
Old Mar 17, 2013 | 07:58 PM
..kris..'s Avatar
do you know where the wiring harness looking plug goes coming off of the oil pump!? i did a clutch re[placement and now my car isnt turing over and notcied that the plug from the pump wasnt connected and have looked EVERYWHERE for the answer. any help would be much appriciated
xPRimNT
157
Dec 26, 2018 08:09 AM
mbnworld
For Sale - Part Outs
69
Aug 25, 2016 09:39 AM
fi8tzer0
Nov 23, 2015 11:15 PM
Stinkhammer
Aug 11, 2013 07:40 AM
Dan@Assaultech
55
May 29, 2012 09:24 AM
