Exhaust Wraps
Old Jul 4, 2009 | 01:42 AM
Junkyard's Avatar
Ceramic coating plus wrap is good, wrap alone promotes rust though.
Old Jul 4, 2009 | 06:14 AM
travail's Avatar
Originally Posted by MMMR0820
Thanks for the info guys. Any pics?
Old Jul 4, 2009 | 06:18 AM
bbyevo8u's Avatar
is it a good idea to wrap the exhaust manifold?
Old Jul 4, 2009 | 06:19 AM
bbyevo8u's Avatar
whats Ceramic coating, is it a spray?
Old Jul 4, 2009 | 06:52 AM
TommiM's Avatar
http://www.performancecoatings.com/headercoatings.html
http://www.jet-hot.com/headercoatings.html
I used to hear that this is better than the wrap. I guess there is an issue of rust due to moisture collecting inside the wrap from condensation of heat cycles-- or so I was told. I wonder if the heat wrap can actually quiet down an exhaust though? Would be an extra benefit.
Old Jul 4, 2009 | 07:03 AM
2LOFD3ATH's Avatar
It should make the vibrations from it softer yet the actual exhaust note loulder, ill test with my sound reader when I do mine if nobody beats me to it.
Old Jul 4, 2009 | 07:58 AM
apagan01's Avatar
Has anyone done exhaust wraps on any of their Evo's? Do you reccomend it?
i wraped my down pipe, because it makes it easier to work under the car when its super hot
Old Jul 4, 2009 | 10:03 AM
bbyevo8u's Avatar
can i buy this stuff in autozone and spray it myself??
Old Jul 5, 2009 | 07:51 AM
MMMR0820's Avatar
Originally Posted by travail
Thanks man, that's a good looking engine btw. How much boost you workin with on high boost?
Old Jul 5, 2009 | 08:01 AM
darkside4G63's Avatar
sorry for the off topic, but i have to ask..... what is with the 3 cut from a licence plate in the engine bay?
Old Jul 5, 2009 | 08:07 AM
2LOFD3ATH's Avatar
A ground line likely.
Old Jul 5, 2009 | 08:36 AM
McLaren F1 2003's Avatar
i had my downpipe swain coated. the best stuff on the market. the white lightening exhaust coating only comes in white. although i personally like the white, but if that doesnt tickle your fancy, the rough texture of the coating makes a perfect base for a high-temp paint
http://www.swaintech.com/
Old Jul 5, 2009 | 09:42 AM
TommiM's Avatar
I think I have seen some ceramic spray- on paint. If they do carry it, I wouldnt think it would be as good as sending it to swain, jet-hot,etc. type of places.
Old Jul 5, 2009 | 09:47 AM
TommiM's Avatar
Why do you say the swain tech is superior? Im just curious.
Does that white coating leave that powder residue stuff whenever you grab it? I used some white ceramic coating once and it always did that when you working around the exh manifold..
Old Jul 5, 2009 | 10:16 AM
tweaker41's Avatar
How long did it take you to get the DP back after you sent it in? I got a few things I was thinking about sending in.
