new clutch YAY, now onto another problem... BOO!!
Old Jul 5, 2009 | 09:21 PM
mayday3k's Avatar
well i have just gotten my car back from the shop and the ACT clutch is great with new ACT flywheel, but now i have a problem, which is when i am in gear and get on the gas it kinda bogs out and all you hear is my BOV with a lot of air. I too notice that i do not hear my fuel pump, and also i think my car is leaking some green fluid... possibly antifreeze.. but im more concerned with the bogging out. i used to hear a high pithc noise while in the car... thinking it was my fuel pump, but now i dont hear it. The car is fine under easy driving conditions but when i get on the gas it bogs out... fuel pump, injectors???? HELP
Old Jul 5, 2009 | 10:51 PM
EvoJoeIX's Avatar
did you do the install of the clutch? if not take it back to the shop, all them problems can be related to things not done right on the clutch install
if your fuel pump wasnt on, the car wouldnt run...
the green fluid is antifreeze
check all your IC pipe connectors
sounds to me, the car ran fine, clutch was installed, now your having problems. basically what you do is check everything that is removed or moved out of the way while doing a clutch job.
Old Jul 6, 2009 | 12:30 AM
manofhonor's Avatar
take it back to the shop and argue with them. check all your intercooler pipes, and coolant pipes.where is the leak happenning? i agree with evojoe, its potentialy something not done right on the clutch install
Old Jul 6, 2009 | 03:17 AM
tortyklubevo's Avatar
+1 on bad install
Old Jul 6, 2009 | 05:14 AM
Smike's Avatar
the green fluid id antifreeze
This.
Old Jul 6, 2009 | 05:30 AM
JakeTheVIII's Avatar
Yea they didn't re-install something correctly.
Old Jul 6, 2009 | 05:34 AM
mayday3k's Avatar
yea i will be calling him today and asking whats up... i figure i would ask here to get some ideas as to what could have gone wrong.
Old Jul 6, 2009 | 06:42 AM
elijahcole92's Avatar
I had to get a new radiator when my clutch got replaced as well.
Possibly hitting it while not being careful? idk
Old Jul 6, 2009 | 07:09 AM
binh's Avatar
Sounds like they "borrowed" your fuel pump and lower intercooler pipe, sliced your rad hose, and swapped your ecu.
Sorry man, I wouldn't even bring it back to that shop for them to try to fix it
Old Jul 6, 2009 | 07:11 AM
mullen's Avatar
well im betting on a serious boost leak, and find out where the antifreeze is coming from...both are easy fix
Old Jul 6, 2009 | 07:20 AM
EvoJoeIX's Avatar
you have to take the bottom rad hose off to do the clutch, so either when they did some spilled onto the car and made a pool somewhere and now your seeing it leak off, or the hose isnt on correct
take it back to the shop. get what you paid for, dont let anyone tell you different. clutch installs arent cheap, so id want them to make sure my car is perfect when its done
Old Jul 6, 2009 | 07:22 AM
mullen's Avatar
ya id be the same way if i payed someone to do work for me
Old Jul 6, 2009 | 07:27 AM
sk8terdude929's Avatar
They prob left a hose clamp loose and one of the IC couplers could be leaking or blown off; but i would def take back to the place the work was done, thats what you paid them for.
Old Jul 6, 2009 | 08:10 AM
srtboostin22's Avatar
no you dont :] but it does sound like they did it
joe
Old Jul 6, 2009 | 08:43 AM
dsevo's Avatar
I didn't take the lower radiator hose off when I took my trans out.
