Putting car down for 7months
Old Jul 6, 2009 | 03:18 PM
kanyonkid's Avatar
goin on deployment next month.. my only concern is how much gas is "best" to leave in the tank? I was thinkin that if i left the least amount possible in there that it would be so low that it would definatley turn into mulchy goo and maybe stick/corode to the tank.. So i was thinkin maybe a 1/4 tank with fuel stabalizer..
Obviously the car will run like **** the first tank of gas regardless, what are your opinions?
Old Jul 6, 2009 | 03:22 PM
bluebanana23's Avatar
do your method, put car on jacks, disconnect battery
Old Jul 6, 2009 | 03:23 PM
alicea8541's Avatar
I've done seven deployments and always leave half a tank. Never had a problem when I have gotten back. I definitely drive kindly until that tank has been filled with new gas though. Are you a Marine?
Old Jul 6, 2009 | 03:26 PM
Boricua_Evo's Avatar
+1 Currently on my 9th dep and never had a problem even with full tank...
Old Jul 6, 2009 | 03:36 PM
kanyonkid's Avatar
ok, not a marine... in the navy.
But ya its goin up on jacks, remove battery, ALL fluids being drained
I jus wanted to know what to do with the gas.. half a tank sounds good
Old Jul 6, 2009 | 04:15 PM
This is what I found in an STI forum... Some of the stuff you can disregard depending on where you live
http://thinking-about-storing-my-car.html
If you are going to store your car for a period of more than two months, the following are recommendations to follow.
* Fill the tank with gas and add a gas stabilizer to keep your gas from becoming stale.
* Change the oil and filter.
* Thorough wash the exterior of the car, wheels, and tires. If possible, remove each wheel and thoroughly clean them. Especially the back side where dirt and road debris accumulates. Polish the wheels and reinstall. Polish/wax the exterior. Clean/detail the engine bay. When the car is sufficiently cleaned and the paint treated to a good coating of carnauba wax or polish, consider covering it with a quality car cover from California Car Cover or Big Sky Car Covers, or another high quality cover.
* To prevent tire flat spots, use jack stands to raise the car off the floor. Set the stands under the control arms so that the weight of the car is still on the suspension, and just high enough to keep the weight off of the tires. Putting the jack stands under the spring perches is recommended by many. If jack stands are not available you can use wood blocks. Just remember that the suspension likes to be loaded. It's heavy. Many recommend that you just inflate the tires to the max and put carpet squares under each tire.
* Check the tire air pressure and be sure all four tires are the same correct pressure. Note that regular air can leak during storage due to faulty valve stems, wheel irregularities, etc. Costco warehouse stores use nitrogen to fill tires. It is the only place that I know of that has nitrogen due to the expense of the equipment I guess. However, nitrogen is preferred for a number of reasons. The most important IMO is that it is heavier than air and is less likely to leak out (larger molecules). So if you have a Costco in your area consider replacing the air with nitrogen. You'll have more consistent air pressures without leaking.
* Disconnect the negative battery cable. When you're ready to take it out of storage hook it back up. Some prefer to use a battery tender.
* Place a few moisture absorber packs (desiccants) in the interior to absorb any moisture. Large packs are usually available at most do-it-yourself building supply or hardware chains. A couple of bags on the front and rear floors, as well as a few more in the trunk, and you'll have dampness protection for the entire winter season. As an alternative, kitty litter can be used in small containers.
* Get some Arm & Hammer baking soda to put in the cabin. Open the tabs and place the entire box on the floor. I'll put one box on the rear floor and one on the front floor. This will prevent any musty smell.
* Cover the car with a high quality car cover. The cover will keep the paint surface clean and protect it from scratches if you (or others) will be working around the car.
* Inflatable bubble covers are also available. You basically drive your car into the bubble and inflate it. Users state that air is continually kept flowing through the bubble and this totally keeps out all moisture. So rusting of the brake rotors, for example, is not an issue. I don't know anything more about this method so you should research it before using it.
* Change your oil again when the car comes out of storage.
* When starting the car after long term storage, hold the accelerator to the floor (which will turn off the fuel injectors) while starting. Turn the car over for about 10 seconds to get the oil flowing to the top of the engine. Then start the car normally. It is also recommended to pull all the plugs first so the starter isn't working against compression. It is my understanding, though, that if you have a BAP it can render this trick useless, reportedly due to the upgraded wiring coming directly from the battery.
Old Jul 6, 2009 | 04:28 PM
abdizzle's Avatar
Talk about overkill.
Old Jul 6, 2009 | 04:54 PM
oneofakindtrini's Avatar
The best way to do this is to Leave the car on jacks, drain all your fluids. Where is it staying?
Old Jul 6, 2009 | 04:55 PM
joeyhauser's Avatar
id say to just let it sit as is. everytime i deploy i have someone start my car every week. never had any issues
Old Jul 6, 2009 | 05:01 PM
hawaiievo's Avatar
been an three deployments, also navy. i left it with a full tank to prevent condensation in the tank and added full stabilizer. was up on jackstands, washed and with a car cover on it in a self storage that i rented out. roommate did the exact same thing with his Z06 and both cars ran perfect when we got back.
Old Jul 6, 2009 | 05:02 PM
kanyonkid's Avatar
my car will be in my garage... My house will be locked up while the family goes back home to california, so nobody will be starting my car.. im actually gonna do that baking soda thing haha, makes sense
Old Jul 6, 2009 | 05:23 PM
That is overkill in my opinion but hey to each is own, just trying to throw some people's ideas out there...
I just disconnect the battery and left in my garage, my wife is in the house so that's as good as it gets
Old Jul 6, 2009 | 05:35 PM
Kracka's Avatar
Full tank of fuel with stabilizer. I also always stuff a towel into the exhaust when storing a car too to keep rodents from making a cozy new home. Oil change before and after storage. Pads under wiper arms to hold the rubber blades off the glass. Dryer sheets on the floor mats. Tires at 45psi to prevent flat spots. Battery removed and charged every few weeks/months as needed. Windows slightly cracked if storing the car indoors to allow air circulation.
Yup, I'm **** and did all these things plus more when storing my S2000 for the winter
Old Jul 6, 2009 | 06:07 PM
kanyonkid's Avatar
hmmm.. so should i keep all fluids in the car? Just replace them all when i get back? I was gonna leave everything empty. (oil, tranny, tcase, reardiff)
Old Jul 6, 2009 | 06:34 PM
justboosted02's Avatar
use a full tank of gas with stabilizer, and leave the fluids in the car. just swap them out when you get back
