Ceramic coating and heat extraction coating of parts
I am collecting all of my parts to get coated and I wanted to make sure I get this right...
Ceramic coated parts include:
exhaust manifold
turbo hotside
o2 housing
down pipe
hot side IC piping.
Heat extraction coated parts include:
FMIC
cold side IC pipes
intake manifold
My question is -- what do you coat the cold side of the turbo? or do you not coat it? Would a ceramic coating help hold heat in and get it moving quickly to the FMIC for cooling?
exhaust manifold
turbo hotside
o2 housing
down pipe
hot side IC piping.
FMIC
cold side IC pipes
intake manifold
I would use heat extraction on the hotside ic piping instead. why would you want heat to stay inside the ic piping? use heat extraction on the cold side to expel the heat out faster. its called the cold side, but it gets pretty warm when your boosting.
not with a good FMIC -- my cold side wont rise but MAYBE 20 deg over ambient..
I think that the hot side pipes should still be ceramic coated -- but its only because your trying to keep the heat in and moving.. ? you dont want it to slow down in the pipe?
I donno really -- just lookin for some... pointers.
You've been told by several people that heat extraction on the LICP is the right way to go, and imo their reasoning is correct.
say the FMIC is only cooling the air to 90 degrees and another FMIC can cool the air to 80 degrees, that means the coolside will be 10 degrees cooler
The reasoning in the IC piping being ceramic coated - was because of its proximity to the motor, and the poor airflow that it would see. It would benefit more from being shielded from the heat, rather then try to dissipate the heat from within it.
This is what I was told from the coating company.
Heat extraction????? is this serious, because this would be the first I have heard of this as being a coating.......You got info on this?
The point of ceramic coatings is to keep the heat in, same as exhaust wrap etc...
