A/C Wire Cut, Need A Little Help.
Old Jul 26, 2009 | 08:11 AM
LetsGo82nd's Avatar
My A/C has been out for a while and since I don't really use it I wasn't in a big hurry to get it fixed. While draining the radiator today I noticed that one of the wires going to the compressor is cut and is probably the source of my problem. This is the wire that runs very close to the LICP. There is another wire that looks similar running on top of the compressor. Any one have any idea what this part is called and has anyone else had the same problem? Thanks.
Old Jul 26, 2009 | 09:36 AM
EvolNinja's Avatar
Cut it and soder new wire to the length you want j/k I guess it depends on how big the cut is. Maybe you can get some liquid tape and paint over the area it's been cut. Or you can get new ones from Mitsu.
Old Jul 26, 2009 | 09:49 AM
LetsGo82nd's Avatar
Well the wires are pulled out of the plastic connector so I think just getting a new wire would be the best bet. Anyone know what this wire is called? I guess I could try posting in the part number request thread. Thanks for the help.
Old Jul 26, 2009 | 11:40 AM
LetsGo82nd's Avatar
Ok, found another thread with some good info from member CO VR4. "The plug for the A/C compressor is shown as having a black with yellow stripe wire. It is a black plug with one wire connector. It is A-36 in the configuration diagram (page 80A-4 and 80A-5), and is listed as MU802653."
The wire that is cut on mine is the black wire with yellow stripe. Looks like the only way to fix this is going to be get a new connector and splice the old wire into it. I took the connector off but can't figure out how to take it apart to run the wire back into it, can this be done or should I just order a new one? Thanks for the help.
Old Jul 26, 2009 | 12:18 PM
Berts24's Avatar
I would just suck it up and buy a new connecter, with all the people taking off their A/C you should be able to find a used one if a new one is too much $$. Might as well do it the right way to avoid a problem down the road
Old Jul 26, 2009 | 12:23 PM
LetsGo82nd's Avatar
Thats what I am thinking, only problem is that this connector and wire is on the wiring harness side. Connector and wiring on the A/C compressor side is fine. Worst case I will just bring the busted connector to the dealership tomorrow and pick up a replacement. At least I know why the A/C stopped working now
Old Jul 26, 2009 | 12:45 PM
barneyb's Avatar
I think you will learn what you are buying is a new wiring harness. I never heard of a single wire or connector being sold, but feel free to prove me wrong. However, if I am right and if you can't figure out how to fix it, take it to a mechanic or some shop that does electrical work on cars.
Old Jul 26, 2009 | 06:41 PM
LetsGo82nd's Avatar
Haha, I guess I will find out at the dealership tomorrow. If its going to be really expensive, I might just have to continue on without AC.
BTR
AEM EMS
Jun 23, 2016 09:56 AM
driven168
Jun 12, 2016 07:18 PM
Jetech38
Jun 16, 2015 03:26 PM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
S3CR3T
Jun 14, 2013 06:15 PM
