Quieter evo? dynamat? ur thoughts?
Dynamat is good product and it works, only problem is the weight and cost.
But it is worth it if you are looking to reduce the noise.
P.s: This is stupid, not because he want a quiet car mean he choosed the wrong one.
Remember; he is asking if it works and not if he bought the right car ....
Here are some comments/tips about deadening an Evo for audio:
https://www.evolutionm.net/forums/ev...ml#post7307517
Dynamat / Fatmat / Raamat are all the same things, and work very well. Also try to find any sorts of holes in your car and plug them up, put some heat liner under the hood, and one point that gets missed alot.. THE ROOF... Dynamat / Fatmatting that will absorb ALOT of of the noise.
I don't lie!
i was reading some import magazine i got a free subscription too when i went to hot import nights and they were talking about stripping the interior of the car and covering it in dynamat, they actually did it on this man's car and said it made a huge difference, what you guys think? i know its an evo and suppose to be loud but when i drove down to miami for 3 and half hours if the car was quiter it would of helped out alot, they dynamat the entire interior and truck and it only added about 60 pounds to the car, anyone on here tried this and know if it really works? cause dynamat is not cheap
. Ill use dynamat but its pricey unless u no someone
to give u a deal in bulks
Why post if ya got nothing good to say
Here a pic! See the back liner of the rear seats! Do the backside of it helps a lot. I also took the cloth liner of the trunk and took a piece of carpeting and traced the shape of the liner onto it. I then cut the carpet and installed a niece piece of carpeting as oppose to the cheap oem one. This helped a little bit as well.
Looks great /good job
Evo1001
50
Nov 5, 2016 11:50 PM
