not holding idle??? WTF???
Old Aug 13, 2009 | 09:12 PM
  #31
kaymin's Avatar
but a car will start even with a dead alternator. As long as the battery is charged.
Old Aug 13, 2009 | 10:54 PM
  #32
SixOneNine's Avatar
^No it will not.
Old Aug 13, 2009 | 11:01 PM
  #33
kaymin's Avatar
Originally Posted by SixOneNine
^No it will not.
Well maybe if the alternator is completely dead. I know for a fact my car ran with a bad alternator till the battery was drained.
Old Aug 14, 2009 | 01:06 PM
  #34
nonschlont's Avatar
update:
ok, so I finally got it figured out and the car is running again... YAY!!!
So the issues (2) were, one of the coilpacks went bad, and wasnt generating any spark! And the other issue was one of the relay wires to the FP (not the plug) but the other 2 wires, one of them was pulled out a bit further than the other one. Plugged it back in w/ some needle nose pliers and changed the coilpack, and all is well! so far...
Charlie (C-Spec) came to my pad to help me out and got it all squared away. Thanks Charlie!
Old Aug 14, 2009 | 08:49 PM
  #35
kaymin's Avatar
sweeeet. Good work on getting that fixed up real quick!
Old Oct 10, 2010 | 06:35 PM
  #36
dastallion951's Avatar
BOOST LEAK TEST.....if u have a loose coupler or a major air leak no matter how much cranking you do it wont stay with an idle, and no matter how much u rev the throttle as soon as you let off the throttle she dies out...theres how to's on here on how to do one ....uve already ruled out the battery and if it was the alternator the car would die after driving for a while once u shut it off.
good luck
Old Oct 10, 2010 | 06:58 PM
  #37
evoboi005's Avatar
good luck
at bumping over a year old post and he posted he fixed it a year ago
Old Oct 10, 2010 | 07:14 PM
  #38
rdt1's Avatar
I would say check your battery!
Old Oct 10, 2010 | 07:40 PM
  #39
evo8426's Avatar
reading threads FTW!
Old Oct 10, 2010 | 10:20 PM
  #40
well honestly with how long all these threads can be i read the first page for the problem, then offer a possible solution...dont have time to read every post to each thread...if you got that kinda time more power to ya...i dont haha
Old Oct 10, 2010 | 10:25 PM
  #41
gieri002's Avatar
He solved the problem.....
Old Oct 10, 2010 | 10:35 PM
  #42
EVO8emUp's Avatar
nvrmnd
delta6force94
Jan 20, 2016 05:43 AM
prozak
Mar 20, 2014 02:20 PM
03evilution
41
Feb 8, 2013 11:57 AM
llDemonll
May 17, 2012 06:00 PM
jeffbum
Dec 3, 2007 11:45 AM
