Stock fuel injectors!
Old Aug 11, 2009 | 05:29 PM
Evojj25's Avatar
Question Stock fuel injectors!
yo was up everyone! i need to know what size are the stock fuel injectors on a 2003 evo 8. i have looked every where and cant find any info for it. can someone help me with this. i'm getting ready to tune my evo.
Old Aug 11, 2009 | 05:43 PM
NsinEvo8's Avatar
560cc
Old Aug 11, 2009 | 05:48 PM
Evojj25's Avatar
Originally Posted by NsinEvo8
560cc
ok so there are 560cc. ok then. well i want to upgrade them, but the guy that is going to install them said that i will need like a fuel system thing like a program or else my car will not start. is that ture bro?
Old Aug 11, 2009 | 05:54 PM
NsinEvo8's Avatar
How big? Injectors need to be scaled. I installed larger ones on mine without being scaled and it turned on fine.. All you need is a new 255lph fuel pump with larger injectors, and definately a tune
Old Aug 11, 2009 | 07:24 PM
Evojj25's Avatar
i was thinking about going with 850cc.
Old Aug 11, 2009 | 07:32 PM
Evostacio's Avatar
yeah your car might start but it wont run properly you need to scale those injectors by using ecuflash...
Old Aug 11, 2009 | 08:44 PM
Sassaphrass's Avatar
im tossing 1000cc's into mine and its a must to get it tuned to right correctly(duty cycles and what not).
Old Aug 11, 2009 | 09:16 PM
Evojj25's Avatar
ok, but if i dont want to use 850cc, what kind of injectors should i go with that my car will start. bc the day i install the injectors will be the same day i will get it tuned. could i go with 650 or 750cc?
Old Aug 11, 2009 | 10:11 PM
EatSleepBoost's Avatar
you could try. it is just not recomended. Your injector latency and scaling needs to be tuned. 750's aren't gonna help u much if ur upgrading ur turbo. may evo's use 880's, 1000's or sometimes even bigger to run e85
Old Aug 11, 2009 | 10:16 PM
evo@24psi's Avatar
Whats done to the car to need bigger Injectors?
Old Aug 11, 2009 | 11:32 PM
chaotichoax's Avatar
+1
is there a reason you are switching?
Old Aug 11, 2009 | 11:52 PM
Evojj25's Avatar
no i'm not upgrading my turbo yet. i have the big 16g turbo on my evo, not the little 16g.
Old Aug 11, 2009 | 11:55 PM
Evojj25's Avatar
installing a walbro 255 fuel pump, greddy boost controller, evo 9 metal bov. i might be pushing between 21-26 psi.
Old Aug 11, 2009 | 11:57 PM
Evojj25's Avatar
Originally Posted by chaotichoax
+1
i want to have some better injectors before i tune my evo
Old Aug 12, 2009 | 12:00 AM
bigger doesn't mean better it just means bigger...for what you are doing stock injectors are just fine
