Scratching Dash and interior Pieces?
Old Aug 13, 2009 | 07:19 AM
Danner's Avatar
Anyone ever notice how easy it is the scratch the plastic interior in this car? I was installing my Gruppe S 3 gauge pod, and my phillips head screw driver just resting in my hand leaning on dash, and put about a 1/4" scratch on my dash right next to ignition. Its not noticable, very faint, but still its a scratch and it annoys me.
Anyone have this problem, and how did you fix it?
Old Aug 13, 2009 | 10:42 AM
gabeamaro's Avatar
dont hold a screwdriver in your hand and get close to the dash?
Old Aug 13, 2009 | 11:00 AM
revvin9k's Avatar
Carefully light a lighter next to the said scuff on the dash and quickly rub with your finger.
If done right, it will blend with the rest of the dash.
Old Aug 13, 2009 | 11:01 AM
inco9nito99's Avatar
Bill, we need to talk .
Old Aug 13, 2009 | 11:02 AM
revvin9k's Avatar
On lunch mang, call me.
Old Aug 13, 2009 | 11:31 AM
akemi27's Avatar
ummm check the part out section?!
Old Aug 13, 2009 | 02:55 PM
Danner's Avatar
lol good idea with the lighter. Its not a huge scratch, but im just really picky about seeing scratches. Its no longer than a taint whisker.
Old Aug 13, 2009 | 05:52 PM
SeeCoryRun's Avatar
Ive had really good results from a heat gun used VERY lightly and from a distance. A hairdryer may work, but Im not sure if it would get hot enough.
Old Aug 13, 2009 | 06:50 PM
EvoDom's Avatar
my interior use to scratch reeally easy, just got to be careful with how you get in and out of the car, and your actions inside while driving .
my biggest problem was my shoes on the lower part of the door, getting in and out.
Old Aug 13, 2009 | 07:19 PM
alexisrc's Avatar
I used a heat gun with great results!
Old Aug 13, 2009 | 07:24 PM
Mitsutech56's Avatar
+1 for the heat gun. Takes all minor scratches right out.
Old Aug 13, 2009 | 09:25 PM
Appauldd's Avatar
Yep....heat gun works wonders. Makes the dash and any plastic look new again. Just don't get it too hot.
Old Aug 14, 2009 | 05:22 AM
Danner's Avatar
So you apply heat then rub with finger? Or just apply heat and glaze over the scratch so it blends in?
Old Aug 14, 2009 | 05:25 AM
Appauldd's Avatar
Simply apply the heat in circular motions. Don't hold the heat in one spot too long or you will create a shiny spot. You will see the heat start to work. Be patient.
Don't touch it with your finger...you could leave perminanat finger prints.
I google search on the topic will yield several how-tos
MisUnderStood
May 3, 2016 06:46 AM
SarcasticWeasle
Jul 11, 2013 12:05 PM
BoostedAWD91
Jul 13, 2012 06:04 PM
ralliartyz250
Nov 6, 2010 10:25 PM
mikeyboy86
May 5, 2010 11:09 AM
