Cheapest place to buy oem t-case fluid
Old Aug 18, 2009 | 04:56 PM
mitsuclipsegsx's Avatar
I am replacing my T-case, rear diff and tranny fluid, and Im using oem fluids. Is dealer the only place for stock fluids? I called up and its about $100 for both fluids
Old Aug 18, 2009 | 04:58 PM
ak47po's Avatar
Thats cheap.
http://www.mitsubishiparts.net/catalog/?section=575
bottom of page.
Old Aug 18, 2009 | 05:07 PM
EvoJoeIX's Avatar
yes the dealer is gonna be the best place to get OEM fluids....
100 is cheap
i think when i replaced my trans fluid with diaqueen awhile ago, i paid 130 just for the trans fluid..
id switch over to amsoil, best decision i made
Old Aug 18, 2009 | 06:04 PM
tweaker41's Avatar
Get a hold of Russell at mitsubishiparts.net for the best prices on OEM. I think I paid around 130 for diaqueen tranny fluid and gear oil.
Old Aug 19, 2009 | 08:58 AM
apagan01's Avatar
100 is cheap
Old Aug 19, 2009 | 09:22 AM
Void21's Avatar
Unforunately gear fluid is expensive, I used royal purple and I ended up spending about $75 on just the rear diff and tranny.
Old Aug 19, 2009 | 10:14 AM
mump's Avatar
STM had it cheaper too...
Old Aug 19, 2009 | 10:22 AM
TxEvo8's Avatar
Be careful getting it from the dealer, I was given the wrong stuff and it cost me a T-Case. Only buy it if they sell it to you in a sealed container. A local dealer bought it in a 55 gal drum and told me to bring a container that he filled, three t-cases that we used the fluid in failed. He gave me the wrong stuff...
Old Aug 19, 2009 | 10:27 AM
yahu's Avatar
rear diff and t-case shouldn't run you more than 30-40 bucks for 1 gallon (which should be all you need). Tranny fluid (a gallon) is quite a bit more, so if a dealer is quoting you $100 for both, and it is OEM then I say go for it!
The closest dealer to me wouldn't sell me the fluids as they said they only have them in larger quantities (barrels) that they use themselves. I think the parts guy I was speaking to was full of crap but I didn't bother with them anymore.
Old Aug 19, 2009 | 10:29 AM
yahu's Avatar
Agreed with Tx, and I wouldn't trust a non-sealed container of the correct fluid either.
Old Aug 19, 2009 | 10:46 AM
funks's Avatar
hmmm, the Transfer Case & Rear Diff fluid is 39.14$ in mitsubishiparts.net website ("Diaqueen LSD Gear OIL SAE90"). Or you can use AMSOIL SVG (Severe Gear Lube) although it's slight cheaper just to use the Diaqueen LSD Gear Oil (you get a gallon for 40$ - if you go SVG, talk to OilDoc - he has the best prices hands down on AMSOIL stuff).
The "Diaqueen 75W85 Manual Transmission" fluid that costs 94.72$ is for the Six Speed Tranny (and it's not the one used on the Transfer Case, and Rear Diff). There's another vendor here that sells tranny fluid for the Six Speed that doesn't cost an arm and a leg (Castrol Syntorq - https://www.evolutionm.net/forums/ev...available.html).
BTW, If you live in Southern California - you'll get the fluids cheaper when buying them from South Coast Mitsubishi (30% discount).
Old Aug 19, 2009 | 12:59 PM
EmeryatSTM's Avatar
We sell it at a real fair price.
http://www.streettunedmotorsports.co...diy_fluids.htm
-Em
Old Aug 19, 2009 | 10:56 PM
chaotichoax's Avatar
plenty of answers given
search for more
closed...
Dallas J
Sep 10, 2019 11:45 AM
asu11
May 31, 2013 07:54 AM
drocksmash
Northwest Region
Dec 12, 2010 11:43 PM
cash
Mar 18, 2010 05:20 PM
scherejs
26
Mar 8, 2008 11:23 AM
